Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ40 ( XJ81 ) (https://www.jaguarforums.com/forum/xj40-xj81-25/)
-   -   Urgently. need help with car parts (https://www.jaguarforums.com/forum/xj40-xj81-25/urgently-need-help-car-parts-182827/)
lenavarrete 05-27-2017 03:55 PM
I have a Jaguar XJ6 sovereign 1990 and am at a car junkyard and found a jaguar xj6 1996
i need a fender, hood, front defense and radiator, frot lights roght and left
can i use any of the parts from the 96 for my car?
also, i found a 1993 xj6 too...
lenavarrete 05-27-2017 04:08 PM
I found a 1993 jaguar xj6 too.
Lawrence 05-27-2017 04:47 PM
You can use all of the body parts, lights, bumper and hood from the 93 - not sure about the radiator, it may be different on a 90.
You can't use any parts from the 96.
Larry
Don B 05-29-2017 11:55 PM
That's not strictly true.... There are various parts from a '96 that may fit a '90, such as the wheels, certain suspension parts (front spring pans, spring packers, upper ball joints), the differential and halfshafts, the thermostat cover, possibly the engine coolant temperature sensor, the cruise control actuator, the windshield wiper arm, parts of the J-gate, and other bits and pieces. But it would take a lot of research to figure out what to grab off of the '96. The '93 is a much better bet!
Cheers,
Don
lenavarrete 06-01-2017 03:31 PM
Thank you, so I grabbed the parts (except the radiator) and I will post here when they are ready
Don B 06-01-2017 07:58 PM
I should have mentioned earlier that if the interior color of the '96 is the same as your car, you should grab the cupholder/arm rest, which will fit your '90 just fine.
Cheers,
Don
Lawrence 06-02-2017 12:20 AM
For sure Don, but our OP was only looking for
so of course none of these bits from the '96 would fit!:icon_eek:
Larry
Don B 06-02-2017 12:05 PM
Hi Larry,
I interpreted the OP's question, "....can i use any of the parts from the 96 for my car?" to be more general, beyond his immediate needs.
I also interpreted your response, "You can't use any parts from the 96," to be a general statement to the effect that nothing on the '96 would fit a '90.
Communication is a funny thing, especially when it's based entirely on text with no human visual or vocal cues!
Cheers,
Don
