1975 xj6c might be selling?
Hello all,
New member here, looking for some feed back on me possibly selling my 1975 XJ6C. I do not know if you all are purists or open to modified cars, do not wish to offend anybody with my project. Here is the description. 1975 XJ6C burgandy ext., needs paint, hasa couple of rust pin holes but nothing to get too excited about. 1 small dent behind drivers door above rocker panel. Interior is camel, no rips or tears, dash finish needs complete re-do, needs new carpet & head liner. Stock chrome wheels in ok condition. Now for the modifications, Engine & trans; 502 c.i.d. Chev. big block new crate motorinstalled, 440hp 513 ft/lbs,750 Holley, custom tri-y headers, custom stainless exhaust, Msd, Etc. etc. Etc. Turbo 400 trans, completelynew with all top shelf internals & shift upgrades, kevlar bands & clutchs, Torrington thrust bearings, new torque converter, custom1 piece balanced drive shaft,Etc. Etc. Etc. Suspension; !00% new XJ40 front suspension parts (i.e. ball joints, tie rods etc., etc). All front & rearsuspension parts powder coated black!! Koni shocks front & rear, all new chassis mounts front & rear. XJ12 Posi rear end 2.73 ratio, all new half shaft u-joints, also powder coated black!! VERY RARE NEW "Harvey Baily Engineering front & rear anti-sway bars(yes you read correct rear bar also!!) Etc. Etc. Etc. Tires & Wheels; New O.Z. Mito modular 3 piece wheels all 17" with Dunlop SP8000 tires, 225 fronts & 255 rears, custom made just for this car& my specifications. More stuff; Custom made stainless steel 40 gallon fuel cell in trunk with fill from either side of car from stock fill caps. Body; Euro front & rear bumpers have been added eliminating the 5mph shocks and massive rubber bumperettes. Euro lower front valance to match Euro bumpers. Euro front turn signals. Details; The entire installation of engine & trans was done with a "Johns Cars" kit with no drilling or cutting or butchering. The only body modifications was for the dual gas tank fill tubes, and that was just to the inner trunk walls inside the trunk. There is way more but the jist of the situation is is that I have around 20k in receipts not counting my time & labor, and if I do sell this it has to go to somebody who will appreciate this unique car. So what do you folks think? Any interest? Mark e-mail address mjcannaday@verizon.net |
RE: 1975 xj6c might be selling?
Well, since you asked...
First thing I'd do is to invest in at least an acceptable paint job. You'll be lucky to get half of your investment back if the car is not presentable. With all of the expensive performance mods, the car should be a turn-key rocket ship for the prospective buyer to test drive. If I heard "Well, it still needs a....", I'd walk away laughing. As far as return on your investment, coupes seem to be bringing out some collector car money. I'd have gone for restoration versus modification. I think you build a car like yours because you want one, and have to accept the possibility that no one else may share your goals. Best of luck with it. |
I like some of the modifications you made, though my Jags are 95% original. That car must befast.
There is a guy in Finland who also did a XJ-12-C with lots of modifications, and he even adapted a XJ-40 rear cage in a MK-1. He's an engineer so he can get away with it. check his work here: http://jaguar.fiboy.com/ There are all types out there so I would not bother making any excuses for the work you have done. Purists are in the minority.We all modify cars one way or another. It's your car and you can put two engines in it if you like. tell you what: register at Jag-Lovers and place pictures of your car showing the modifications you've made, but don't hint at the selling it, otherwise you get reprimanded because no selling or hints of selling are allowed in the XJ forum over there. Once you got that done, then place a free Ad offering your car in JAGADS, putting a clickable link to the post you made in the ad, so they can see the pics. You mightget a mix of responses, there's a good number of owners there who lump their XJ, (they call them Lumps), converting to GM transmissions and engines, so you're not alone. http://www.jag-lovers.com good luck, I'm sure you'll find a buyer. How much are you asking? Jose |
Welcome quack!
Where are the pics of it at? You should add photos to your picture gallery on here so everyone can look at it. One thing to keep in mind... [sm=ttiwwp.gif] |
pictures would be a definent here for starters
complete interior/exterior pics would be great with modifiacation pics as well where are you located? being a long time jag tech who knows i might be interested |
Hello folks,
Ok,ok.....I will try to post some pics. All the pics I have on it are from my pre-digital camera days. I have had poor to worse luck with my printer/scanner at getting reasonable copies of old paper photos. Soooo..I will try some new ones with my digital. Man....now you guys are going to make me pull off the car cover and deal with dust and spiders. I can not wash the car since it is now traped in my garage by my 1950 Spartan travel trailer thats blocking the door, and it's torn apart at present. So these are going to be some pretty dusty pictures. I will try to get to it this weekend. Mark |
Hello again,
Failed to tell you where I'm located. I'm in the greater Seattle area. In my list of what the car has, I also failed to mention it has all new Stainlees Steel Brake Corporation rebuilt calipers and new stainless steel lined master cylinder, all running dot 4 fliud( no more Girling type fluid). And the rear Koni shocks have fully adjustable ride height collars, and I have a pair of front springs that should put the ride height down about 2" from stock. Man....I know there is more & more & more, just need to vacuum out the cob webs from my cranium. Mark |
Sounds like you have a lot of work to do before you try to sell this beast.
ORIGINAL: ken@britishparts.com Sounds like you have a lot of work to do before you try to sell this beast. yeahh, like 4 hours worth of work to pull the trailer back out and out of the way, pull the car back, wash it, take pictures, push the trailer back in before the car, then push the car back in after the trailer.If the neighbor helps, that's less work. [sm=signs003.gif] |
Charge the battery and see if it runs.....etc.
I'm looking forward to pics...
Hey folks, maybe you all have the wrong idea! First off the car runs great right now, there is no"charge the battery and see if it runs" situation. The engine hasthe initial25 minutes run time on it, 20 for the cam break in & 5 for when the exhaustwas installed, and then maintenance fire ups since then. It has however, not had a four wheelalignment since all the new suspenson was installed. The only issue is that it has sat untouched (other than maintenance) since I bought my major money/time pit 110 year old house!
Secondly, there is no swapping places with my trailer in the garage. My trailer is a 33 foot 1950 Spartan Royal mansion (very art deco) and my garage is only 28-1/2 feet deep, and thereis already2 othercars and 2 motorcycles hiding in there. Lastly, I may not get to the dusty picture this weekend, had yo go help my aging parants all day Saturday, just got back home now at 6:30pm. I will try none the less. Mark |
Wrong idea is posting stuff for sale w/out pics! LOL:D
No pics of the car as you modified? I am going crazy waiting for pics! LOL!;) |
I said "maybe for sale". I also needed to help my parents out all day on Sunday too, so no pics yet....sorry, but family first you know.
Mark |
Hello folks,
Finally had time to take a couple of pic's. Yes the car is veryyyy dusty, please look past that. Mark [IMG]local://upfiles/4168/B7A4AD0F4BAF4089BF027344F6518B8A.jpg[/IMG] [IMG]local://upfiles/4168/131153FD723E4280A6CACBA3E656158D.jpg[/IMG] [IMG]local://upfiles/4168/AA168319DC6448B4A2349D706A9AF69C.jpg[/IMG] [IMG]local://upfiles/4168/B9545BC3D652452B8B387F4AFB55500E.jpg[/IMG] [IMG]local://upfiles/4168/AA03058B9C8E4F7A95B076CF5ABB3AEB.jpg[/IMG] |
Ok more pic's
[IMG]local://upfiles/4168/CAA728D1E95C4CA5B651DBD676A7EFB8.jpg[/IMG] [IMG]local://upfiles/4168/9CB94A02E07F4AD4A411A59886A907E5.jpg[/IMG] [IMG]local://upfiles/4168/A447FE10782246C6A5DE22599A9ABD23.jpg[/IMG] [IMG]local://upfiles/4168/42DA82FE9EFB4F0A80341524E034C2C2.jpg[/IMG] [IMG]local://upfiles/4168/BE7C2000740E4FC68192D6E8436EB220.jpg[/IMG] |
Ok the last of the pic's
[IMG]local://upfiles/4168/810D113DBDEB47BC9223CB0880749FC3.jpg[/IMG] [IMG]local://upfiles/4168/A7C29E3D22E848F8ACAC084D3E475940.jpg[/IMG] [IMG]local://upfiles/4168/212A603547AA4846833079A8BBB03BA5.jpg[/IMG] |
