1984 jag xj6
which side the injector coil wire + or _
and on my coil both side is positive and my fuel injector pin is positive on both side is that right? |
Hello, Joe,
If you post your question here: https://www.jaguarforums.com/forum/x...s-i-ii-iii-16/ someone will be along shortly to answer you. Welcome to the forums from ElinorB. (';') |
If you are talking about the injector coil, yes.
If you use a test light with the ignition "ON" you will have power on both wires. The Computer will create the ground as needed. |
