1986 Daimler VDP
Hi All , Can anyone advise the difference between a 1980 Daimler double six and 1986 ,both VDP as far as the 2nd edition hard back drivers handbook as I can buy a 1980 book but unable to find a 1986 edition and as I have not seen the book is there a technical difference in the cars that would make the 1980 book not worthwhile. John.
I have a 1986 Vanden Plas handbook in my website, actually the entire folio. Check it out.
It appears to be the same booklet as the Jaguar XJ-6 4.2 but not the 12 cylinder. 6 years would definitely make a difference, the 1986 and 1987 were the last 6 cylinder models of the XJ and Daimler Series 3, and by then the cars had changed quite a bit in more than one ways so the 1980 book will not relate to your car. |
Jose is right. Lots of changes from 1980 to 1986.
Some of the fundamentals would be the same so the 1980 version might be better than nothing......but just barely. Cheers DD |
Thanks Jose, How do I find the link to you web, Regards.
Thank You DD ,I have been looking for the hard cover book for years, I recieved one with the 81 Sovereign V12 but not the 86 VDP apart from all the other booklets and service records, Regards
1980 = Pre HE and Bosch D Jetronic EFI,m and Opus Ignition, steel cooling fan.
1986 = HE, P Digital EFI, GM HEI Ignition system, Plastic cooling fan. Same trans in both. Thats the VERY BASICS of differences. Different beasts in many, many ways. |
Originally Posted by prettydaim
(Post 2087979)
go to the Parts page. Remember this is not a 12 cylinder folio. However, other than the engine, the rest should be the same. |
Thanks Jose I will have a look Regards J.
Thanks Grant, I am really very grateful for the advice you all are so willing to give Much Obliged ,J.
