1986 XJ6 aligment specs
can anyone provide the FRONT alignment specs for a 1986 XJ6, or provide a link for same?
thnx gatz |
Toe: 0" to 1/8" toe-in
Camber: .50º negative, +/- .25º Caster: 3.25º positive, +/- .25º Note: these specs apply to VIN 360147 and later Cheers DD |
thanks Doug....
one more question. what is the effective year of VIN 360147 |
Sorry, I meant cover that. Late 1983 model year.
A change in upper control arm geometry meant different specs. The service bulletins and parts catalogs don't agree on the exact change point but your 1986 car would clearly use the later spec Cheers DD |
by "later spec" you mean the figures you gave in the 1st reply ?
Yes, later spec = specs shown in earlier reply = applicable to your 1986 car
Cheers DD |
