1986 XJ6 Series 3 vapour pipes.
Hello everyone,
Would someone help with the following? :
How would the engine of a 1986 XJ6 Series 3 behave if all or any of the three vapour pipes are accidentally disconnected from its Carbon Canister CAC3814?
Vapour Pipes: CAC8900/11--CAC2641/1--CAC3889. Thank you.
Received 2,399 Likes
Tis a somewhat complex but workable system to reduce emisions into the atmosphere.
In earlier days, gas tanks were vented via the gas cap. No longer, now, they are supposed to seal. I have my doubts as to the sealing on mine. I do have new ones, but that is way down on the to do list.
Now, the vapor/vapour is "stored" in the charcoal filled canister. And, from time to time, the engine has a "purge' valve that opens and cleanses the canister.
Eventually, it will fall far behind and/or the charcoal degrades and it doesn't work. Change the cannister or merely the charcoal in it. Most cars went to the wrecker way before this.
As I understand it, the one way valve allows the vapor to flow from tank to cannister, but not back to the tank. Tis a tiny orifice anyway. So, piercing it changes little, Vapor flows, engine purges, it stays out of the atmosphere.
True, the engine gets a tad more fuel when the purge is cycled, but, lost in the whole mix of things.
Disconnect it and the tank vents to the atmosphere. And the engine purges the atmosphere!!!
Along with catalyctic converters, just doing good, with no engine harm.
Air pumps are another matter. But, for another day.
Carl
Carl
Jag7651 (01-30-2015)
rusty37
04-05-2020 07:40 PM
pnwrs2000
01-15-2018 07:20 PM
Miles86XJ6
09-14-2015 01:08 PM
