1990 Vanden Plas Passenger Side Door Won't Open
Old 06-08-2016, 06:49 PM
Angry 1990 Vanden Plas Passenger Side Door Won't Open
Front passenger side door won't open from the outside. Electric door lock and inner door handle works.
Attached Thumbnails 1990 Vanden Plas Passenger Side Door Won't Open-img_0150.jpg   1990 Vanden Plas Passenger Side Door Won't Open-img_0151.jpg   1990 Vanden Plas Passenger Side Door Won't Open-img_0154.jpg   1990 Vanden Plas Passenger Side Door Won't Open-img_0155.jpg   1990 Vanden Plas Passenger Side Door Won't Open-img_0157.jpg
Old 06-08-2016, 08:35 PM
Is the car in question (and what IS the question? ) a 1990 xj40 car or a 1990 Series III V12 Vanden Plas (Canadian market).? The door locks are quite different. The lock mechanism in the photos does not look like a Series III lock to me.
The xj40 did have door handle (exterior) problems and the solution was replacement of the handle mechanism. But if the car is an xj40 then you will get a better answer on that forum.
Old 06-08-2016, 08:39 PM
1990 XJ6 Vanden Plas, Front passenger side door can be opened from inside but not outside. Threaded rod from outer door handle appears bent and just slips in and out of whatever (?) it's connected to (can't really see.)
Old 06-09-2016, 01:12 AM
Your car is known by the factory code xj40, and there is a separate forum for that model. But it sounds like you have the problem I mentioned: the outside handle failure. The handles were redesigned internally, I believe, to correct this issue but if you present this to the xj40 forum you'll get a better response.
Greggbhill
07-15-2019 04:09 PM
hlgeorge
04-23-2016 11:54 AM
xjsman89
04-13-2016 12:52 AM
Mad_Russian
XJ40 ( XJ81 )
04-10-2016 08:06 PM
buttpt
03-31-2016 04:48 PM
Quick Reply: 1990 Vanden Plas Passenger Side Door Won't Open
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
