2" SU's, HS8. Banjo bolts?
Hi, can you get longer banjo bolts for the 2" hS8 carbs? Pleeeease someone say yes you can :) The start if my thread for the bolt is not good, but have noticed that there is a lot more thread to be used. I would prefer to just put a longer bolt in, rather than re thread.
If anyone know please let me know. Thank you!!! |
I am NOT aware of any banjo bolts on the HS series carbies.
The HD series certainly does, however. Maybe SU Midel in NSW can help with your request. They have got me out of the "brown stuff" over the years. |
Your right :)
Your spot on, thanks, they are hd series. I will give them a buz tomorrow. Fingers crossed! Cheers
Originally Posted by Grant Francis
(Post 1044704)
Midel were unable to help. But you would not believe how easy it was to find one. I feel a bit inbarressed for even asking the question now. Just went to my local hydrateck store, and bang problem solved, purfict length, just what I needed.
Aussie intuition, get outside the box, problem solved.
