4.2L engine number/year
Old Jan 22, 2018 | 01:57 PM
yachtmanbuttson's Avatar
Default 4.2L engine number/year
I do not have a "numbers matching" XJ6C.
My fender plate says VIN# UF2J 51008 BW
It also says the engine # is 8L 20640L
On the back of the block, drivers side I see 8L 40403L
Any way of telling what the 8L 40403L block is out of? Year? Etc.?
Old Jan 22, 2018 | 07:15 PM
davidboger's Avatar
My guess is probably going to be around the 77/78/79 model year..
I've tried to record the engine numbers of some of the cars I've parted.
I had a 75 Coupe that had eng# 19630L (car #50566)... then another Series 2 (not sure of the year, but I think it was 77), that had 29294L .... by 12/83 the number had jumped to 149199 (!)
Hope that helps narrow it down a bit...
Cheers,
David
shop.EverydayXJ.com
Old Jan 23, 2018 | 03:14 AM
o1xjr's Avatar
Originally Posted by Grant Francis
I knew it was somewher, so I copied my TERRIBLE scribblings into a word doco.
Attachment 125637
If there are hiccups, so be it, thats all I have.
The V12 stuff is also there and I will scribe that when I feel like it.
ENJOY.
Old Jan 23, 2018 | 09:20 AM
XJ6Paul's Avatar
I can't remember the full number at the moment but the engine number in my car from a 1975 donor XJ6 begins 8L165**. I don't have the actual build date of the donor car.
Old Jan 23, 2018 | 09:54 AM
littlelic69's Avatar
I understand that series 2's had engine numbers with a 7 prefix and series 3 had an 8 prefix!!
Old Jan 23, 2018 | 11:30 AM
Tar's Avatar
Tar
Have a look at XJ6data.com. You may not get exact information, but the engine numbers are listed for some cars, which may give you an idea.
Regards,
Andrew.
Old Jan 23, 2018 | 02:46 PM
Thanks, tried that and registered my XJ6C but couldn't find other engine numbers.
Old Jan 24, 2018 | 04:23 AM
o1xjr's Avatar
Jaguar XK engine decoder.
This is for the 4.2litre engines only.
7A30001> 4.2 Daimler Sov
7D50001> MK10 and 420G
7E***** E Type S1 & S1.5
7F1001> 420 Compact
7L***** XJ6 S1
7M***** DS420 Limo
7R***** E Type S2
8L***** S2 onwards.
The inclusion of the “L” is for long stud engine.
All others are what is known as short stud.
Havebook
Oct 25, 2023 02:46 AM
peterg19
Apr 18, 2015 08:51 AM
theJPster
Oct 19, 2014 05:49 PM
fullitorrrrrrr
Nov 5, 2012 05:23 PM
jadedragon1800
Apr 19, 2011 10:40 PM
