'83 fuel hose size?
Gents,
Anyone know the correct size fuel rated hose from the saddle tanks to the selector valve in the boot? it fits on a nub fitting on the bottom of each tank, then a short piece of hose, then an aluminum tube into the boot, then another longer section of hose to the valve. 1/2" seems to small and 5/8" too big. Thanks! -Cabel |
It's 1/2" as far as I know. That's what I've always used on the fittings that are actually in the boot. I don't recall using anything different on the nubs right at the tanks....but it's been a long day.
Others will chime in Cheers DD |
It's 7/16. I have a text document with all the fuel hose sizes, locations and clamp numbers if you need it.
Originally Posted by muttony
(Post 2064633)
That chart with Hose/clamp sizes would be a great tool to have as I want to change everything also. Can it be posted?
I'll take a photo of it and post it when I get home from work tonight. I don't know if I wrote down the clamp sizes but I'll see if I can't scare up the sizes. I bought a box of assorteds and ended up running out because they're all like one weird size and Advance Auto near me didn't have any proper fuel hose clamps.
https://cimg0.ibsrv.net/gimg/www.jag...5279a7a7a1.jpg
The Clamp SIzes I used most IIRC were 13-15mm mostly. Biggest were 15 -17 mm IIRC. Anything smaller than the 13-15mm and you will struggle to get them on. This is a compendium of what others wrote but what I used when replacing mine maybe amonth ago. Get extra 5/16". |
