85 Series 3 Inline 6 / 4.2 Mass Air flow Question
Deleted
until coming up with a better picture from the S57 Doc Thanks Doug for the tip |
What you're seeing, probably, is the 'cold running' modification, designed to prevent over-fueling when cold....although many have reported a general improvement in behavior hot or cold
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling I suggest using the wiring diagrams from the S57 Wiring Guide. It's in one of the sticky threads at the top of this section Cheers DD |
Can't find S57 wiring guide that opens up to get to the MAF diagram
I did see the TSB on Cold Start EFI Over fueling on pin 6 and 8 with a 100uF capacitor |
Hi, here are the links to Jose's main site ( the guide is under the "contact/manuals/links tab at bottom ).
Jag Upgrades Home Here's the direct link to the manual download. https://static.secure.website/wscfus...ries-3-xj6.pdf All thanks to Jose, nice to have a digital version to backup my paper copy purchased years ago. Cheers ! Brian |
