85 Vanden Plas Intake Manifold Sensors
My intake manifold has what appears to be four sensors screwed into its top: front to back is the thermotime switch (part of the cold start circuit), next (right behind the coil) is what looks like a screwed in sensor with a single green (ground?) wire attached, in the third position is the water temperature sensor (which I'm replacing) and last is a screwed in sensor with two wires attached. Can somebody identify what #2 and #4 sensors are?
Received 10,749 Likes
#4 is a temp switch that, in conjunction with the air switching module, operates the air injection pump diverter valve.
The air switching module is mounted on the RH inner fender, near the diagonal engine bay brace. It also has some degree of control over open loop/closed loop switching and (as I recall) the electric cannister purge valve.
jpbmass (07-22-2017)
