87 xj6 -- how to remove center console?
So the wood on the console is severely warped and cracked, would like to replace the piece on the center console with vinyl or something...undecided. How can I best take apart the console for this job??
If you just want to remove the wood grain panel around the gearshift it isn't too hard.
It's been a while so what follows might not be exact right down to the last letter but it should get you in the right direction... remove ash tray inserts remove ash try housings----two screws each remove cubby box liner---several screws visible with lid open remove connectors from the back of the switches remove single screw at the very top of the "ski slope" just above the switches remove rubber seal at base of the gearshift housing remove wood grain panel The sloped part with the switches is bolted to the wood grain panel....you'll see. The wood veneer can be scraped off and replaced with black vinyl. Looks very attractive, actually. Oh, the ashtray housings are fussy to reinstall (you'll see). Longer screws help. And to take the cubby box out you'll also have to pry out the friction latch. If you break it it, you won't be the first Shout back if more help needed Cheers DD |
Thanks DD, will try that in the morning. Since it's going to be out, I may try something more wild than vinyl.
Friction latch officially busted, never even saw it coming. Didn't have to remove the rubber gear shift base though....mainly because I couldn't...lol
Originally Posted by tsingtao35
(Post 213150)
New latches are readily available from the usual Jag suppliers :-) RTLL |
Decided to go with basic black vinyl, came out quite nicely. Took you suggestion about the ashtray harness and actually reattached them to the console board before re-entry into the car....no fussing with it at all afterwards.
Doug, do you know if the dash wood is also attached to a single piece of metal much like the center console? For a split second, I almost decided to reveneer another piece of wood to the center much like I did to my 67 MBZ but decided to go with just vinyl.
(Post 213300)
The main dashboard is a plywood piece about 5/8" thick with a veneer. It has a metal backing plate screwed on Cheers DD |
So now the car won't start all of a sudden, did I mess up something during my console removal and install? I thought it was the battery since I bought it last week and the car was not driven often before. Did the starter crap out coincidentally? All electrical functions are good, just won't crank.
Originally Posted by Doug
(Post 213308)
Cheers DD I have an 85 XJ6 Series lll Vanden Plas. My shift console is black leatherette and I would like to change the two level wood panel below the tray hood and above the radio and comsole to black leatherette. How do you remove/replace the radio and trip computer panel? |
Originally Posted by BoBird
(Post 1309227)
It's been a few years so a couple details are a little foggy, but this should get you in the right direction: - Remove trip computer. It pulls straight out. Just get your fingernails under the edges. Disconnect wiring plug - Remove climate control knobs. - Remove the shaft nuts behind the climate control knobs. - You *might* have to remove the radio....but maybe not. - Look upwards from below the panel. You should see two screws above the radio. Remove them - Gently pull the bottom of the panel towards you and away, then slightly downward. The top of the panel has tabs that should disengage - Remove wiring from switches, cigar lighter, etc Cheers DD |
:icon_worthless:
Originally Posted by pnwrs2000
(Post 1309466)
:icon_worthless:
You've just been volunteered! Go out to your car with a camera, remove the panel in question, and take pics along the way. Then post them up ! :) Cheers DD |
3 Attachment(s)
if the console lid CATCH is busted, you can go to any home appliance store and get a Dryer Door replacement Catch. They are the same as the Jaguar part.
Maytag, GE, and other brands of clothes dryers use the same catch. You might even get them in black. |
(Post 1309570)
Cheers DD |
(Post 1309466)
:icon_worthless:
Cheers, |
I wasn't asking Doug for pics - it was meant for tsingtao35 tbh. Nevertheless, I wasn't being serious :icon_doh:
the Factory Service Manual provides the steps needed to remove 95% of anything you want to remove.
you can go to XJ-6 - XJ-12 'HOW TO' quick links (always located at the top of the topic list), and download the .pdf file for any section of the car you need, or you can download all the sections. Free. the Service Manual files are located near the end of the list of How To's. |
