'87 XJ6, Tracing wires using S 57 Manual.
Old 06-13-2014, 12:09 PM
Default '87 XJ6, Tracing wires using S 57 Manual.
Hello Friends,
I've been trying to solve a running rich and missing problem for quite some time, but right now, I will jump right to a specific part of my troubleshooting.
I'm checking continuity on all of the wires shown on figure 24.1 of the S 57 manual. In the center of the diagram is the Diode Pack alongside the Main relay, and Pump relay. I have disconnected the battery, removed the doide pack, and both relays.
A continuity check using a digital ohmmeter between terminal 4 of the diode pack, and terminal 86 of the main relay indicates full open-no continuity. On the diagram it looks simple. One white wire between the two units, but under the hood(bonnet, sorry) the white wire from each unit disappears into two separate looms. where do they go, and is there something tied in between them? I was considering using a jumper wire directly between them to see if that would improve the engine miss, but chances are that could be very bad.
Can anyone out there offer any suggestions?
Thanx so much for listening!
George
Old 06-13-2014, 12:39 PM
Received 6,547 Likes on 4,859 Posts
I'm not aware of anything between the two points but a bigger question is how the engine runs at all with no power to energize the main relay. Something else is afoot, methinks
George M. (06-13-2014)
Old 06-13-2014, 08:14 PM
Thanx Doug!
I see what you mean. I'll dig a little deeper this weekend.
George
Old 06-14-2014, 07:41 PM
Ok. I hooked everything back up, and then I measured voltage from terminal 4 of the diode pack and got 11.95 Volts.
Then, I measured voltage from terminal 86 of the main relay and got 11.61 volts. ( IGN key to position 2).
At least I know I have power. Why no continuity between the two terminals? I'll never know.
I'm now testing the diode pack. I'll share results on a new blog.
Thanx again,
George
aholbro1
05-08-2019 09:20 AM
pnwrs2000
01-15-2018 07:20 PM
Steve10
09-09-2015 07:54 PM
rusty37
09-08-2015 06:16 PM
Quick Reply: '87 XJ6, Tracing wires using S 57 Manual.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
