94 XJ6 heater problems
My 94 XJ6 does not blow out heat in the front. I get heat to the back seat vents. The blower is fine, just no heat. I am full on coolant and appear to have no cooling issues. Any help figuring this out would be appreciated.
RE: 94 XJ6 heater problems
Did you ever get your answer?? I have the exact same problem on my 1994 XJ6 that I just bought and really want to know if this will be a costly repair or hopefully a quick fix?? I am in Denver and it is getting cold...can someone out there help us out??
PULL THE PASSENGER KNEE BOLSTER DOWN TOWARDS THE CENTER CONSOL ARE TO ACTUATOR MOTORS ONE IS STUCK.TAP THEM BOTH WITH A HAMMER AND THEY MAY START TO MOVE IF NOT THEY NEED TO BE REPLACED.THEY ARE BOTH THE SAME, SO I CANT SAY EXACTLY WITCH IS GIVING YOU WOES.
