Aging oil
I have a 1977 XJ6C, which sees less than 1500 miles use per year. It gets a 20-30 mile drive every month at least, to keep the gaskets intact (and for sheer enjoyment). I use Mobil One 5W30, which, needless to say, looks perfectly clean after a year and a half in the engine. Is there any need to change the oil based purely on the time it has been in the engine?
________ 1999 XJR |
RE: Aging oil
IMHO you should change it at least once a year as oil can become acidic with use as and will contain condensation unburnt fuel etc.
RE: Aging oil
I agree, but being as anal as I am, I would say every six months. Just the short trips driving, startup etc....not great for the oil.
RE: Aging oil
DITTO;)
RE: Aging oil
Thanks for the replies, chaps. I will follow your advice.
________ 1999 XJR |
RE: Aging oil
If you get it out every month and get it up to temp and run it for 30+ minutes at steady speeds, you will burn off the vast majority of condensation and fuel from start-up. As long as the carbs are in a good state of tune and not running pig rich I would have no issues with 2 years...I'm assuming the car is kept indoors in a climate controlled environment.
RE: Aging oil
As cheap as oil is, (sorta speaking:D)why go the two years?..Every six months is a good measure..But if you burn the gas less..then add the correct amount of Stab-Bil to the gas to keep it fresh.
http://ace.imageg.net/graphics/produ...1253695reg.jpg |
