Aluminum Rear Cover
I used to buy most of my racing parts from Speedway Motors. They still send me a catolog and in it I found an aluminum rear cover. Link to this item from Speedway: http://www.speedwaymotors.com/Finned...over,3805.html
Can you guys tell if this cover fits an 82 XJ6? Pictured is the $90 unpolished cover-I think. The polished cover sells for $150 and should be much shinier.:cool: Does anyone else carry these...maybe even cheaper? They are made by Mr. Roadster. I questioned them about supplying a gasket as well and will let you know if one is provided with it. [IMG]http://i544.photobucket.com/albums/h...92547009_R.jpg[/IMG] Thanks~Paul |
Fits Dana 44 rears, gasket not included.
Dana 44's AKA Salisbury rear ends are found in XK120-XK150, some E-types, and XJ6 Saloons. Also used in Ford trucks, AMC, front gears of US made 4x4's, Sunbeam Tigers, 283 and 427 Cobras and most likely found under other British made vehicles. I think these covers would look sharp under any cat! Anyone have one like it? |
An alternative for bone yard pickers....
The 88½ and later XJSs have a very nice finned aluminum diff cover. You'll need a 1" freeze plug to plug off the speedo sensor hole which you wouldn't need. Cheers DD |
