Jaguar XJ6 4.2 Series 3 1980 | update thread |
Old 04-22-2018, 11:08 AM
magnetron's Avatar
Default Jaguar XJ6 4.2 Series 3 1980 | update thread |
Hi all!
From now on iŽll create a topic that I can update weekly or monthly! IŽll do a lot to this jaguar XJ6 to have it in better conditions than now.
I have had some issues with my light switch: I took it apart and tried to fix the issues, after sanding down the coper parts, it does work, but so not nice yet. Its quiet heavy and if i wiggle the switch, its flickering the lights. Not satisfied yet, but nice to show you guys the inside!
Left light doesn't work yet. Will replace!
21-04-2018
Yesterday at an Jaguar forum (Dutch) meeting, I have found this amazing peperpot wheels!
Old 04-22-2018, 01:34 PM
magnetron's Avatar
Today I also bought my: Jaguar STAKEDOWN, HOLDDOWN KIT, TAPPET GUIDE, SELF-TAPPNG - NBM0001 set.
I have had serious ticking in the area of my my valve covers. This must be an issue with the valve tappet guide that has come loose.
I bought this set
The covers will fit on top of the valve guide ->
https://www.jaguarforums.com/forum/x...own-kit-68777/
Or: https://patsjags.smugmug.com/Restora...eve-Stake-Down
Old 04-22-2018, 06:29 PM
Jose's Avatar
Received 2,429 Likes on 1,828 Posts
it could be the fuses in the engine compartment headlights fuse box not being tight inside their brass "spring" connectors. Have you checked those fuses?
there are 5 fuses, one per headlight. The 5th fuse is for the auxiliary electric fan.
also, the insides of the headlights switch needs dielectric grease, it looks too clean.
Old 04-26-2018, 03:36 PM
magnetron's Avatar
Hi all!
New wheels update: I found a nice set of Original Peperpots 15". They have been in a grage for years.
I found a place in Amsterdam where I could sandblast them myself. Amazing result so far.
The following 2 users liked this post by magnetron:
Doug (04-26-2018), GGG (05-07-2018)
Old 04-26-2018, 04:59 PM
iramphal's Avatar
Nice wheels and they look brand new too - are they?
Old 05-03-2018, 03:54 AM
magnetron's Avatar
Default Pepperpots Silver
The Epoxy has hardened out, and now I apply the first layer of 'Silver'
I'm quiete happy with the first results.
Old 05-07-2018, 02:02 AM
magnetron's Avatar
Default 15" Pepperpots are DONE!
So the result may be not perfect, but I am very happy. I have picked up a second set of pepperpots in Groningen (very north of Holland), in good condition, but the best part is they had the original logo's in them. So that was great!
They have left the logos during spraying, so a lot of overspray from the previous owner was on them.
I started using Terpetine (almost everything came off)!
Yesterday I finished the 2 component paint. 2 layers, and the final result is more than OK for me
Doug (05-07-2018)
Old 05-07-2018, 04:58 AM
Rustyxjc's Avatar
Those look like brand new wheels! Did you sand the center stars smooth or fill them?
Rusty
Old 05-07-2018, 05:32 AM
GGG is online now
Received 16,794 Likes on 12,165 Posts
You were lucky to find a set of Pepperpots. Great refurbishing job.
Old 05-07-2018, 04:12 PM
magnetron's Avatar
Rusty
Great gentleman, thanks for your replies!
I found actually 2 sets, and refurbishing them both. This was my very first set where I did a proper job. Learned a lot.
The process:
1: Sand blasting (did not do that perfect, and that is why I still have some rough edges.
2: even then out with an epoxy primer /filler, 2component (see previous post)
3: 3 layers of silver
4: 2compnent clear coat
5: not yet but will bring them to a shop where the edges will be polished completely.
Then I want to see the overall result, do it all again with my 2nd set and that one goes on eBay for a nice price or maybe I can sell it on the forum! (I'll do it because I like the process, I work for a software company and this is what I really enjoy next to the office. Haha).
Old 05-08-2018, 06:11 AM
Dutch-Cat's Avatar
Dat ziet er goed uit....that looks good!
Old 05-08-2018, 11:32 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Very nice work.
I could only ask ? What media was used to blast them. Sand is a rough substance. Glass beads or even 'softer" media available.
Not a criticism, by far, only a question.
During the project before the Jaguar, I had a medium sized blast cabinet. It lead to a larger compressor. Not big enough for a wheel.,
But, I did hubs and a ton of smaller stuff. rust removal was my challenge. It "finished off " my old shoulders so it is gone. I do miss it from time to time, shoulders and all.
They are getting a work out today. Ugh, laundry and floors and bedding swap.
Carl ,
Old 05-08-2018, 01:11 PM
magnetron's Avatar
Originally Posted by JagCad
Very nice work.
Carl ,
Hi Carl!
Nice post, thanks. I used sand, and this big cabin.
45 minutes including material €52 (65 usd?)
Old 06-12-2018, 01:46 AM
magnetron's Avatar
Default Jaguar XJ6 4.2 3 series 1980 "Valve Tappet Sleeve Stake Down Kit"
Today I have taken the time to assemble the "Valve Tappet Sleeve Stake Down Kit" on my valve-shim conductor houses
Photo 1: It can clearly be seen that something has already been performed at the middle (right sdie) shim guide. This is the "Simple" way of solving this problem. (High engine damage can occur because the camshaft can "break" the entire conductor tube. What also immediately is spotted by me on the right set, that the camshaft has "run-in damage". Also if you look underneath, you also see immediately that the entire "conductor" is worn by the camshaft, if you compare left (extremely) with Right (one-to-last) you see an extremely worn shim conductor tube.
Photo 2: Here we see a quick example of how the metal plates should hold the aluminum conductor tubes.
Photo 3: Here a zoomed picture of the camshaft / shim guide * (completely worn down). Time to secure it.
Photo 4: I use strong magnets to get everything in place so that I can drill.
Photo 5: Here is another angle of the affected shim conductor tube that the previous owner already dealt with himself.
The camshaft had to be removed to remove the previous "repair". I will not do this. So I leave it that way. (with my own metal plate)
Photo 6: The new valve cover gasket. Here you see on the right two sides that I have put the shim conductor tubes. Left (first test) I have unfortunately failed, here I drilled with a 3.5MM drill, and the thread was 4MM so too much force broke the bolt. It's a shame, but these shim conductor tubes look like new, so I'll leave this for now. (yes I am a hobbyist, and not a perfectionist) I think its successful.
Photo 7: Test ride, warm engine, and NO tapping noices anymore!! YAHOO !! It has all worked. Totally spend 6 hours on this job.
Old 06-20-2018, 04:16 PM
magnetron's Avatar
Default Maintenance!
So, i have been busy with the window wiring, and it was a complete nightmare!! I can do a some things myself, but wiring, damn, next level! haha Never went deep in to that.
I brought my car to: Beek Classic Wire a local guy who does amazing work.
So, here's an BEFORE photo, trust me, i disconnected the battery every day haha!! seriously, looks horrible. The previous owner tried to make it work, he actually did until 1 stopped working last week, that was the moment I took of the arm rest and found this mess. Directly went to a prof to make this in good condition:
Today i picked it up and it looks like brand new. Patrick even used the original wire thickness, correct colors and 4 new connectors:
Personally when i had some spare time, I tried to refurbish my window switches: Great result, and all work fine!
Before:
After:
Trying to find out why my electric windows are not working! did not found the problem yet.
I"ve also taken off the antenna as it was broken!
The windows work fine, the right front window motor is broken, so need to replace that one!
Old 07-15-2018, 10:23 AM
magnetron's Avatar
So lately, i have been working at the right front window. Its been a job, my god!
I had fitted the new (ebay) arm & motor in, but it did not want to work correctly, the glass as in the video below, was hitting the central locking unit.
I was missing bits here and there...
So, got it better adjusted without window, but after it was still hitting the central locking unit.
THEN this happened..... sorry, learning the hard way.
THen my neighbor girl knew some uncle with an old jaguar, and i was very lucky -> 4Hours later:
I only need part: BAC1804 -> right hand side (LEFT bracket for the window that comes down). TO keep the arm in place. At the moment its popping out.
And here we go, for now, its working 2 cm only, but i need the bracket (Luckly) i found one in the UK. Asked if shipping to holland is possible!
magnetron
09-17-2020 08:01 AM
magnetron
04-19-2018 02:50 AM
cougs
12-16-2013 08:23 PM
garysoldcars
12-20-2009 01:53 PM
secondtonone317
02-24-2008 08:31 AM
Quick Reply: Jaguar XJ6 4.2 Series 3 1980 | update thread |
