A/C Compressor oil leak
Old Jul 4, 2016 | 11:28 AM
DannyRobertHoward's Avatar
Default A/C Compressor oil leak
Greetings to all, I had my air conditioning system re-gassed last week. The a/c man did tell me that he noticed that there was oil leaking from the compressor and there is a strong possibilty that the gas would leak and the system would fail. He also said that there used to be a compressor service kit to overhaul these compressors but they are now obsolete. I have been using the R12 replacement gas R134 for a few years now. He went on to say that if the gas escaped, the only cure would be to fit a new compressor, condenser, receiver/drier, expansion valve, hoses etc. Then I would be using the modern gas and all should be fine. But at a cost of appox £1,000.
Does anybody know if there are any compressor service kits being supplied by anybody? Any A/C experts that might be able to offer suggestions?
Kindest regards, Danny.
Old Jul 5, 2016 | 03:36 AM
Assuming Delco Black Monster compressor??
Not even gassed down here, they simply dont like the 134a pressures.
A Sanden unit is a standard replacement, BUT, it is NOT a plug and play task. Brackets will need to be made, fairly simple for any DIYer, new hoses, and drier, then you will be good for many years.
The compressor you currently have is a GM unit, and maybe ?bay will have a kit, but these units are OLD in any meaning of that word.
Old Jul 5, 2016 | 03:53 AM
Many thanks for your thoughts Grant. Yes, I suppose 32 years is quite old for a compressor that has had no work at all for its entire life! I did see that there is a kit JLM11604 available and it suits the series 3 XJ12. I assume the compressor is different from mine though? Kind regards, Danny.
Old Jul 5, 2016 | 04:47 AM
Same compressor, well should be??.
This is the parts drawing of the Black Monster Compressor.
The seal kit they list is AEU1699 and is listed as NLA. from Jaguar.
I would try an Air Con Indepenmdent, or whatever they are called up there.
Down here that Compressor was used on GM, Ford, Merc, Jag, etc etc.
A/C Compressor oil leak-compressor-parts-drawing.png
Old Jul 5, 2016 | 07:07 AM
Doug's Avatar
Personally, I'd wait for further developments.
Oil leaking from a GM/Harrison A6 compressor is as normal and expected as night time following the day. They leaked a bit even when new. Heck, the old GM service manuals and tech bulletins mentioned that some weeping is normal.
It's all a matter of degree.
Old Jul 5, 2016 | 09:32 AM
Thanks Doug, I appreciate your advice. Kind regards, Danny.
Old Jul 5, 2016 | 09:50 AM
JagCad's Avatar
Agree. A different unit on my 85 Ford 302 powered F150 4x4 weeped.
I noted a wick to carry off the seep away from the clutch. Seals need lube!!!
As long as it is quiet ands cool, I'd not worry...
Carl
Old Jul 6, 2016 | 03:42 AM
Many thanks Carl. I think that the gas must be escaping because the system has lost that "icy" feel from the vents. I will try to obtain a kit of seals before I think about a new compressor. Kind regards, Danny.
Old Jul 6, 2016 | 09:26 AM
JagCad's Avatar
My Jeep has a decal advising that in it's past a sealant was added.
The last time, it failed to blow cold, I added a can of R134 that included a sealant. It worked. Two season, now and it still blows cold.
Certainly worth a try.
Carl
bullittandy
Jun 19, 2022 05:00 PM
yidal8
May 2, 2016 08:40 AM
avern1
Apr 13, 2016 02:30 PM
gthawk1
Apr 6, 2016 01:25 AM
