Castrol Dexron III
Old Oct 20, 2018 | 06:52 PM
chrisleg's Avatar
Default Castrol Dexron III
Hi all!!
2 questions for the group
1 - Any qualms using the castrol Dex/merc for steering fluid? I believe its dexron 3 (see pic attached)
2 - Can one mix a different brand of fluid to the one already in the reservoir to top up etc?
Many thanks!
Old Oct 20, 2018 | 07:45 PM
Doug's Avatar
I wouldn't hesitate, Chris. That stuff should be fine.
To be honest, when it comes to P/steering I just grab what ATF is closest. A long time ago I found myself with a big over-supply of Type F so I used it in P/steering systems for years....even though Dexron was called for. If something bad was supposed to happen I never heard it, felt it, saw it, or smelled it
Old Oct 20, 2018 | 08:19 PM
chrisleg's Avatar
hi Doug
hope you are having a good weekend.
Great. Will use this as it's pretty cheap and I know the brand from the uk.
on my second question. Ok to mix brands?
chris
Old Oct 20, 2018 | 08:45 PM
KrissMotors's Avatar
You might consider Prestone for European cars, widely available in AutoZone, etc.
Prestone steering fluid
Old Oct 20, 2018 | 09:15 PM
Doug's Avatar
Originally Posted by chrisleg
. Ok to mix brands?
chris
Yup!
Old Oct 22, 2018 | 01:57 PM
chrisleg's Avatar
Thanks Kirss!
Old Oct 22, 2018 | 02:12 PM
chrisleg's Avatar
Yup!
Thanks Doug!
Old Oct 23, 2018 | 10:12 AM
JagCad's Avatar
Post lost???
Me and the "new" scroll ?
I use ATF. Why, because I have it. A few ancient cans. needed an ancient can stabber to open the can and the opener has a handy spout as well !!
In the past, I have used dedicated PS, when my Jeep blew out a hose.
Jaguars are European, mostly. The PS pump is pure GM!!!
Just my view, I see little benefit in A PS. Seals in the rack, just maybe.
Carl
Carl
its can xinet cuz it
penguin
19
Jul 20, 2023 12:54 PM
orangeblossom
Sep 22, 2017 12:19 PM
michaem101
Jan 9, 2017 05:35 PM
Bob0927
Dec 4, 2011 08:05 PM
