Chrysler starters and XJ-S?
Old Sep 8, 2018 | 12:21 PM
no1chauffeur's Avatar
Default Chrysler starters and XJ-S?
I was told that Chrysler starters interchange with Jaguar XJ-S cars with 12 cylinder motors. Can you verify that for me, as I would like to purchase from Jeg's Automtive their Part Number: 746-PCE393.1013 for Chrysler.
Old Sep 8, 2018 | 12:46 PM
Doug's Avatar
I've not heard that; let's hear what others have to say.
Looking at the pic on the Jegs website I can't see how it would fit....but sometimes generic pictures are used rather than picture of the actual part
You might be a trailblazer.
Old Sep 8, 2018 | 01:45 PM
sidescrollin's Avatar
I'm not sure I follow. The bolt pattern looks totally different for each. On the V12 they are 180 from each other and on a 440 they are maybe 80? Go to any auto store and ask to see a starter for a 318 or 440 chrysler to take measurements. I can provide measurements for the V12 starter if you don't already have one out.
Old Sep 8, 2018 | 03:41 PM
Doug's Avatar
It's not unusual to use a Chrysler starter relay on older Jags. I wonder if that's what you heard/read?
Old Sep 9, 2018 | 09:35 AM
JagCad's Avatar
Doug:
Yes. that was my thought. Decades ago I used the Chrysler solid state relay on my IHC Scout II. It's Delco starter suffered the hot crank issue of other GM cars. Fixed.
Carl
Old Apr 12, 2020 | 12:08 PM
Hi y'all, I have to apologize for the delay to the forum with my solution to the starter recommendations, but I did eventually buy a hi-torque starter from British Starters. It works well, but was no fun having to take the exhaust down to get it in! I expected a bit more "spin" out of it, but it worked well and that's all that mattered. By the way the motor was made in Japan, and then retrofitted by British Starters, first class job!
Phil isolated in Central Californiastay safe y'all!
Old Apr 12, 2020 | 12:24 PM
sov211's Avatar
Correct...it is the starter relay not the starter motor that is interchangeable.
Doug, I am getting tired of your being right all the time. Couldn't you just give the rest of us a break by unintentionaly posting a wrong answer sometime?
Old Apr 15, 2020 | 04:22 PM
ronbros's Avatar
to add to thread! i replaced my starter with a gear reduction unit, the shop that sold it to me said it was from a Ford!
dont know what year its from, or the Ford engine it fit , but its been working for 26yrs!
replaced starter ,with gear reduction unit
Old Apr 15, 2020 | 04:23 PM
ronbros's Avatar
show pic of starter
Old Apr 16, 2020 | 10:36 AM
JagCad's Avatar
Yours has the big solenoid top side. I don't recall any ford unit that is built that way..
But, tis been a time since I messed with a ford starter, other than the very early ones..... 40's as the latest.
Check rock auo cataloque for about 95 for a V8 and see what it look like Quarantine recreation...o
Carl
Jwhoaglan
Aug 3, 2017 12:11 PM
Jagboi64
Jul 18, 2017 11:38 AM
J_C_R
May 19, 2013 04:40 PM
jagster708
Apr 25, 2011 11:29 PM
