Clunking Noise at Front End
Hi, solved, but wanted to share this with you in case you encounter the same problem.
I noticed a clunking noise at the front end when a torsion was applied to the bodyframe (e.g., when driving up a curb with the left or right wheel) or due to a pothole. I suspected the suspension but everything okay there. I spent some further 20 hrs to investigate where the noise came from.
The rods on top of the engine that increase the rigidity of the body are fixed at the bulkhead and at both wings. The bolt that fixes the rods to the bulkhead had some play. Covered the bolt thread with some heat shrink tubing around it, tightened the bolt and no more clunking.
Jose, I believe the torsion bars on E-types refer to the twisting bars that replace a front suspension spring (like those fitted to our XJ6/12's). I think Willem is talking about the V-shaped bars (tubes really) that prevent the XJ front end from twisting under stress. I would prefer to re-bush that bulkhead fitting instead of taking up any wear with a plastic insert.
Hi Jose, yes that's the V-shaped bars on top of the engine and which are so awkward when working on the engine.
I agree that re-bushing would be the best way to go.
I must say that two garagists had already failed to find the cause of the clunking, it was driving me nuts.
Yeah, those braces need to be really tight or they'll make noise.
While we're on the subject of clunks, the front shocks often clunk from worn upper bushings and/or not-tight-enough lower mounting bolts. I've found that those lower bolts have to be really, really tight to prevent noise. Tighter than you'd typically think. Those noise is identical, IME, to the noise from the engine bay braces.
Elizabeth Blake
Sep 17, 2019 08:12 PM
ThomasX
Jun 11, 2010 06:55 AM
