Coolant temperture
Wanting to check my coolant temp guage in the cockpit. What is the resistance range of the sender. Can someone direct me or send the data from the service manual ie resistance verses temp indication 82 S3 4.2L
From an old J-L posting
First column is temp in ºC and second column is ohms 55 255 60 210 65 177 70 150 75 128 80 110 85 92 90 73 95 62 100 55 I wish I was 100% positive about this info but I'm not, sorry. If your test results are similar to above then the info is probably correct. If you have wildly different results I wouldn't condemn the sender predicated only on what I wrote above! Cheers DD |
Have an issue, but cannot figure out how to manage a new post: 2003 S type 4.2..temperature gauge goes off to cold... limp mode engages... no overheating... turn car off wait a few minutes... problem goes away ( guage works fine)...gauge appears to not be working for that time period... any thoughts on this one.. thanks wordman
Best to post your question in the S-Type section
Cheers DD |
Or another means to measure coolant temperature and compare numbers.
An IFR gun from HF for just a few bucks. Read at about the same place as the sender and compare. Might even find an old capillary guage and plumb it in in lieu of the Jagensor and see what numbers it comes up with!! Carl |
Originally Posted by JagCad
(Post 1076203)
