Cruise control
Ok...my cruise control worked on day and now it has stopped. I check the fuse on the drivers side make speed conto it is a 2amp and it is good. I checked the switch and I havev12v there on one leg and when I turn the switch to on I then have q2v on another leg...so I'm assuming that the switch is good. I then went to the relay under the clove compartment and I don't have any power there at all. Did Jag put another fuse or circuit breaker that I'm missing? Please help.
Did you check vacuum supply to the bellows?
Also, the bellows itself will often develop leaks at the end plates. Easily re-sealed. No additional fuse or breaker. By 'relay' I assume you mean the cruise control module. If you are not getting voltage to the c/c module from the c/c switch on the yellow/orange wire, and the switch is OK, then you have a bad connection somewhere Cheers DD |
Originally Posted by Doug
(Post 1492190)
Yes, the Stalk switch has a black ground wire at the Set Button which connects to another black ground wire at the top center of the steering column. It is a bullet connector. Very easy to make it come off the connector when working in the area. The Blue relay above the Speed Control module is the Wipers Delay relay.
