Daimler Sovereign mk3
Old Dec 27, 2020 | 04:49 AM
Alfie William Lewis's Avatar
Default Daimler Sovereign mk3
Hello and Merry Xmas
my drivers door will not unlock but i am able to unlock doors from passenger door,
any ideas why drivers door is not working ?
Old Dec 27, 2020 | 06:44 AM
Doug's Avatar
Won't unlock with the key? Or won't unlock with the inside paddle? If just one or the other, the respective linkage may have just dropped off. You'd likely have the sensation of this...as the action would feel very loose.
If the door won't unlock with both the key and the inside paddle then the problem is probably with the door latch itself.....perhaps simply being gummed up and needing a good clean-and-lube treatment.
I dealt with this scenario a dozen or more years ago on a Series III I was repairing for a fellow. In that case the latch required replacement although the details of the actual failure escape my memory at the moment. It is possible to non-destructively remove the door card from inside the car. Not pleasant, but possible. Then, with manipulation of the levers and gizmos on the latch to unlock to door. I remember a pocket screwdriver being involved to lift a little lever.....but beyond that it's all foggy in my brain
Old Dec 27, 2020 | 06:49 AM
Jose's Avatar
Hi,
sounds like something became disconnected at the key lock.
try to open the door from inside.
​​will it open from inside?
if yes, open it and remove the door panel or "card" and investigate using a mirror and a bright light, or use the phone to take a video.
Timeisrelative
Nov 25, 2019 11:15 AM
Kingrae
Oct 29, 2017 01:38 PM
Her jag
Sep 26, 2014 09:02 AM
charm11
Feb 15, 2011 07:51 PM
