Electrical Plug under Throttle Body - What is this?
Old Jun 11, 2016 | 08:17 PM
James O's Avatar
Default Electrical Plug under Throttle Body - What is this?
4.2L XK engine from an 84 XJ6, late EFI.
I managed to tear out the wires that plug into the bottom of the throttle body. The plug has three pins but only two are used--the center and the right-hand side (looking at the throttle body). Both wires are yellow.
1. What is this? What are the wires going to?
2. Since both wires are the same color, does it matter if they get reversed? Both disappear into a wiring harness so there's no good way for me to trace them.
I'm looking through the electrical books but stuggling.
TIA,
-James
Attached Thumbnails Electrical Plug under Throttle Body - What is this?-throttle_body_broken_wires_plug.jpg
Old Jun 11, 2016 | 08:31 PM
Doug's Avatar
It's a throttle position switch which signals the ECU to richen the mixture when the throttle is opened xxx-amount.
According to the S57 diagram it just an open-closed switch so it shouldn't matter which way the wires are connected. The wire colors should be yellow/red and yellow/white according to the diagrams
Old Jun 11, 2016 | 09:04 PM
James O's Avatar
Thank you!
I'll take a harder look at the wires under brighter light.
34by151
May 6, 2024 12:20 PM
kenneyk843
Nov 12, 2021 07:50 AM
mark a l
Mar 7, 2020 03:53 PM
frostee
Apr 21, 2016 08:50 PM
dannio636
Apr 6, 2016 10:59 AM
