exhaust temp warning lamp!
Old Nov 10, 2012 | 05:33 PM
Ilja Oblomow's Avatar
Default exhaust temp warning lamp!
Hallo, i just bought an XJ12 Daimler from Japan. I made about 550 km on a Highway with no problems but sometime the exhaust temp warning lamp was warning. I red it is only mounted in Japan cars. Do you know what does it speak for? What should i check? When i drive more then 140 kmh it disappears and is flickering between 100-130 kmh and disappearing in the city....
Greetings form Berlin
Old Nov 11, 2012 | 08:15 PM
icsamerica's Avatar
Check your ignition timing. If your timing is retarded it will cause the exhaust gasses to be very hot. Your xj12 has a centrifigal mechanical timing advance which is known to get feststecken. Also check the vacuum advance unit too.
Old Apr 7, 2013 | 09:08 AM
Thank you very much. I will check the ignition. It dose not light regularly, only sometimes when i drive slowly.
dsnyder586
Dec 29, 2024 07:39 PM
Jandreu
Jun 30, 2022 03:10 PM
Tim Goz
Sep 17, 2015 09:11 AM
Johnken
Sep 15, 2015 05:46 PM
AL NZ
Sep 4, 2015 08:39 PM
