Front Hubs throwing grease on wheels
Old Jun 23, 2023 | 02:57 PM
StillOutThere's Avatar
Default Front Hubs throwing grease on wheels
'78 Jag XJ6L Ser II is throwing grease past the edge of the cap and onto the rim of the wheel. Often, with few miles driven. Are they just over-greased and the dust cap can't hold the heated, expanded(?) wheel bearing grease?
There is no "outer seal" that I can locate in the parts books, diagrams. So I assume that the dust cap is supposed to be stopping this grease.... but it is failing to do so.
Or are my dust caps getting out of round from on-off-on over the last 100 thousand miles and it is time to replace them?
I show the cap as CB-6766. Please verify for these aging eyes.
Advice appreciated. Thank you!
Old Jun 23, 2023 | 05:40 PM
Over greased for sure.
It is common these days where too much grease is injected through that nipple.
2 strokes of a "normal" manual gun annually, is all that is needed.
Old Jun 24, 2023 | 10:11 AM
Thank you.
Old Jun 24, 2023 | 05:37 PM
Doug's Avatar
FWIW I gave up greasing the bearings via the grease nipple years ago. IMO it's a throwback from the olden days when we didn't have the high grade lubricants (and hub seals) we have today.
Properly remove, clean, and repack the bearings with modern high-temp synthetic bearing grease and you can forget about it for years
Old Jun 25, 2023 | 10:50 AM
Chris Scott's Avatar
What Doug said...only thing I'll add is check the bearings before reinstalling 'em, as it's quite possible they're the original ones, and need replacing....check rollers for blueing and do a "pen test" to see if there's any scoring.
Pretty easy task, and when it's done, it's done for a good long run.
Damoco
Aug 1, 2021 07:28 PM
maxiedaniels
May 26, 2020 05:36 PM
ExcelsiorZ
XKSS
Aug 26, 2019 10:30 AM
Time-Pilot
Apr 10, 2018 08:21 PM
vdpnyc
Feb 21, 2017 02:34 PM
