Gas Guage Death
I used to have operable gasoline guage for both tanks, but now they are both dead. I am sure this has come up before, what is the fix procedure?
Most common fault is the sending units. They're cheap, about $54.25 each. What makes me wonder is did they both fail at once? They seems like a rather odd occurrence. If one failed, then the other, I would suspect senders. If both at once, maybe a gauge?....I don't know.
Crawl up under the dash to gain access to the fuel gauge. You'll see a terminal on the guage with a light green/orange wire. Clip a wire to it. Turn key "on" and touch your wire to ground. The gauge should go to full. If not, your gauge is dead or it is not getting voltage from the solid green wire. The latter is not likely....or you'd see all the guages having a problem as they are in series.
If the guage is OK I suspect a problem with the change-over switch. Try jiggling it around, and/or check the connection at the back. Does the switch feel funny? If it feels spongy, that's a clue. Sending units often fail but it would be odd to have them both fail at exactly the same time. Cheers DD |
Thanks fellas. This morning my speedometer wasnt very smooth, it jiggles as it reads the speed. It also does not kick in untill 20 mph....
Check the plug on the transducer.
change-over switch
"If the guage is OK I suspect a problem with the change-over switch. Try jiggling it around, and/or check the connection at the back. Does the switch feel funny? If it feels spongy, that's a clue."
Doug where is the change-over switch? |
Ken, where is the transducer to check my speedo?
Originally Posted by Walter1982
(Post 93418)
Doug where is the change-over switch? You know....above the radio, the one for changing the fuel tanks Cheers DD |
(Post 93420)
Right side of the trans, maybe 3/4 way back, 2 wires Cheers DD |
Thank you Doug
My 85 XJ-6 had the same problem when I first purchased it, no reading at all. The plug behind the change over valve had come loose. Once I pluged it back in, everything worked fine. Hopefully thats all it'll take. Good luck.
do you just pull the switch off the panel then? I do hope that is all it is too!
change
change over Valve or changeover Switch?
__________________ Keith Hodges Little Rock, Arkansas 85 XJ-6, 95 XJS 2+2 Conv 6.0 V-12 Drive them daily to make them last! |
Apparently all of this discussion is over a typo, since the changeover valve in the trunk has absolutely nothing to do with the fuel tank sender reading. He meant to say that the harness connector at the back of the fuel changeover switch on the dash was not properly connected.
Damage to this connector can occur when one of the fuel return solenoids is faulty and drawing excessive amperage: there is no separate fuse for each solenoid, so the current draw can overheat the wiring connector at the changeover switch and damage the switch. If I was working on that car, I would go to each sender individually and ground them, since that is where the faults are most likely. That also enables you to test the gauge and switch. Absent of a reading, Doug's gauge test is the next step. Still no joy and I'd pull the changeover switch and jump across the sender terminals to the gauge and bypass the switch. You need a good wiring diagram, some time to accustomize yourself with it and learning to think like an electron, a 12v test light and a couple of jumper leads with aligator clips. There isn't anything you can't fix by yourself on a 1982 XJ6 if you are so equipped, and the need will arise more often than the appearance of accurate troubleshooting tips. |
el changeoveroo switcharoo
(Post 93474)
you can use Flossing String, nobody uses it anyway. double it and slide it behind each edge of the trip computer, pulling a little at a time. The trip computer is designed to be removed that way, it has a spring bracket on each side. If it refuses to come out, someone opened the brackets, so you will then have to remove the entire panel to get to the changeover switch. The Floss string also works to remove the grille under the wipers. Same way. Jose |
Uh, dude, it's an '82. He doesn't have a trip computer, and doesn't need dental floss.
if the '82 has a Clock instead, it comes out the same way as the trip computer.
Yep I have a clock. It does not work, I have always wanted to toss the junky plastic factory one and find a classy working one instead. Ill try the floss idea. I do need to buy a test light also. Thanks so much.
Kieth, I had a loose connection behind the switch on the dash also. After I pried off the aluminum plate that held the fuel tank switch (and the other switch), I noticed that the wires werent pluged in completely to the switch. I plugged it all back together, put a little black electric tape on it to hold them together, and now my guages are fully functional! Thanks again everyone for saving me time and money and keeping another happy Jag owner on the road with my series 3!
