Help with AB3 wiring
Old Feb 13, 2021 | 03:49 AM
ivan1531997's Avatar
Default Help with AB3 wiring
Greetings, please help. My XJ12L from 74 worked on the spot and just went off, I assumed the amplifier had burned out and after disassembling the case it could be seen to melt. I ordered another one, but I didn’t see that it was from 1980, the difference is in the wiring and the connector. I have short cables and all black wires on the old one, and on this one from 80. Red, black and yellow, there is a difference in the connector as well. I found the schematic in some catalog (I will attach) and put it together as it says, but it still doesn’t work. Another thing, I saw oil leaking from the coil and ordered a transistor ignition coil from our auto parts store, should that fit? I found a circuit on the internet where the resistances on the resistor are written, I measured and everything is fine except the resistance between W and UW according to the circuit should be 8 Ohms, and with me it does not measure anything. Can I put an 8 ohm resistor here, I live in Croatia and there are almost no such cars in our country, maybe 2 in
Old Feb 15, 2021 | 04:58 PM
Jose's Avatar
I wish I could help but I am not familiar with your car's ignition system.
Cannot be that difficult to fix. You could try calling SNG Barratt in the UK or France and ask them. They are very helpful.
scottpeterd
Oct 10, 2020 01:15 PM
jagstuart
Jan 14, 2019 04:45 PM
Jag7651
Jan 14, 2019 10:34 AM
sanchez
Apr 17, 2016 07:42 PM
Wascator
Jun 2, 2013 05:35 PM
