Help with depressurising a/c - XJ12 Series 3
that is the Coil above the radiator. I think the V12 has two coils: a primary and a secondary coils.
the long cylinder in front of the condenser with steel lines on each end is the Accumulator for the a/c refrigerant.
I see the shrader valve on top of the compressor. it has a black plastic cap.
Received 10,757 Likes
In your picture see that pressure switch on the a/c muffler? The gizmo with the red wiring connector? That's where the missing Schrader valve should be. That pressure switch is a non-standard fitment.
Here's a pic of my old XJS. You can see the red plastic cap covering the Schrader valve
Wondering how the pressure from the high side can be relieved without a valve..
Would the schrader valve be beneath the pressure switch? Can the switch be removed safely with the system under pressure?
Edit- found this pic on carsales, looks to have the same switch, may be a standard feature for the late series III v12's in Australia?
Interesting about the pressure switch.
In your case I would simply discharge thru the low side port.
But.....the pressure switch might simply be attached to the Schrader valve, in which case you'd just remove the switch. A small amount of freon will escape as the switch is removed.
If the switch isn't attach to the Schrader valve then you have a large and sudden loss of freon...which can be dangerous
Received 2,399 Likes
alabbasi
11-01-2012 10:59 AM
