Help with running lights
I been working on this car for some time and getting close. Now I'm working on lights and I have all the running lights working but the right rear. I have nothing no running or brakes break lights, not even the side marker light. It is almost like the harness isn't plugged in but, I can't find anywhere that it plugs in. All the fuses are fine. Some thoughts would be great. Thanks
Tom |
As the running lights and brake lights are two separate circuits you *might* have two different poblems.
Or in fact there might be a harness connector problem as you say. I can't remember the location of the connectors off hand. I'll try to get that info and post back To clarify the fuses issue: are you aware of, and did you check, the fuses on the forward bulkhead in the trunk? Cheers DD |
Fuses
I don't see any fuses in the trunk, This is XJ12 not a XJS not sure if you knew that. But I don't have any power at all on that back side of the car. I have running lights on the on the front of the car.
