How to remove the turn signal switch
Old Aug 2, 2018 | 03:06 PM
Montana Dan's Avatar
Default How to remove the turn signal switch
Hey guys,
I've got a few problems with my turn signals.
I've also got a spare steering column so I was going to attempt to swap the switches on the columns since the condition of the spare is far better than the original. However, I'm noticing that the bracket seems to go clean around the steering column. Am I going to have to take the wheel off to do this? I'm really hoping that I'm missing something obvious and stupid.
Old Aug 2, 2018 | 06:00 PM
o1xjr's Avatar
I have done that on my Series 1. Yes it is a steering wheel off job.
Old Aug 2, 2018 | 06:06 PM
Yeah, I kinda figured that out the hard way.
Needless to say... I don't think I'm going to try rebuilding this switch. I could, but I could also do brain surgery on myself with an air chisle.
I think I'm going to clean the contacts on my existing stuff very carefully and pray to the Lucas God for the magic smoke to stay in the battery.
Old Aug 2, 2018 | 07:13 PM
Jose's Avatar
there are step-by-step instructions in the Factory Service Manual.
download it here in the HOW TO XJ6/12
Old Aug 5, 2018 | 06:05 PM
Thanks anyway Jose.
I​​​​​ decided to repair in place instead of replace.
on the flip side, does anyone know where the diodes for the turn signal indicators are located? I'm guessing they're behind the instrument cluster, but I really hope I'm wrong. I've got a bum light on my indicators and it's not the bulb. I've also got a bum light on the same side on the rear light. The front light works fine though. I'm thinking it's a loose wire on the bulb, and I've got a bad diode on my indicators. I'm having difficulty locating the diodes and really didn't want to drop the steering column.
Old Aug 5, 2018 | 06:25 PM
Jose's Avatar
what do you mean "the sides" ?
usually, it is not the diode, been there done that. It is the stalk switch if the bulb in the speedo or tach does not blink.
Old Aug 5, 2018 | 06:54 PM
Sorry about that. Autocorrect error. I meant to say diodes. I was really hoping you weren't going to say that. All lamps fire correctly, it just doesn't show on the indicators. I was thinking it was either the diodes or the flasher. Looking at the schematic you gave me seems to indicate that after those parts the circuits are lamp dependant. My hypothesis was that if it was the stalk it would also affect the signal to the lamps.
Old Apr 2, 2021 | 02:18 AM
adenshillito's Avatar
I rebuilt the hazard switch and that is brain surgery and not sure if patient survived. from the pictures here i assume i am going to have to take out the entire shaft to get at the indicator arm (which i think i might have already killed).
Old Apr 2, 2021 | 05:33 AM
Jose's Avatar
the diodes are in-line with the wiring harness connected to the tachometer and speedometer. Each diode is in the turn signal indicator bulb wire. About 3 inches back from the connectors of each harness to each gauge. You need to disconnect the gauges and then unwrap the harnesses to find the diodes which after all that hassle you will discover they are fine.
loftbed
XK120 XK140 XK150
Jul 2, 2022 05:42 PM
rwilcoxen
Feb 27, 2017 08:14 PM
Edotyelloh
Jan 24, 2011 05:58 PM
Tamy2Litle
May 1, 2010 10:11 PM
