#HowTo ; air intake System in '85 xj6
Hello fellow jag lovers. I'm new around & I'm not all to knowledgeable mechanical field but I can keep up ; so I just bought an '85 xj6 & I want to put a new air intake system but i dont know what to do with the carburetor. Any & every tip or suggestion of instructions will be GREATLY appreciated
Received 6,317 Likes
Welcome to the forum.
For a warm welcome please post an intro in the new member area.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
I'm sure the series 3 owners will be able to help you.
Received 2,399 Likes
Received 10,749 Likes
I'm not aware of any aftermarket pre-fab intake system for these cars. You can get a K&N filter element...but that won't do much at all for power. Virtually, nothing, in my experience.
Some eliminate the filter canister entirely and install an aftermarket cone filter. Might help a little, you'd probably need a dyno to measure the difference.
To be honest there are probably many things on the car that deserve attention before the intake system. For example, that yellow plastic fan. They are known for cracking and literally flying apart...especially common if the fan clutch has seized.... causing lots of damage. That would be a good thing to check on !
Anyhow, welcome aboard
03-13-2007 12:07 PM
