idle speed
hi every one I have a ser3 xj6 efi and need the size of the allen key to adjust the idle speed as mine running in neutral at 1000rpm:confused:
I recall that's 7/32" will do the trick. Wish I could swear to that but I can't.
Cheers DD |
Check for vacuum leaks first.
to anjum have checked for vacuum leaks but every thing seems to be ok took it for a 50kms run today engine seemed to hunt a bit on idle may be a fuel problem as well
