Ignition Coil Leaking Oil
Old Aug 4, 2014 | 10:59 PM
twocross's Avatar
Default Ignition Coil Leaking Oil
Can an ignition coil that has leaked it's oil out and /or the condition that caused the leak have shorted out a fuel injection system component?
Due to the multitude of "+" and "-" connections to the coil I am curious about this.
Old Aug 5, 2014 | 01:03 AM
I am assuming S3 6cylinder here???.
I doubt it. Tacho, maybe, Ign Amp module, for sure.
Those are just my thoughts as I visualise the wiring.
I have not had a leaker, only a few that have exploded, and a new coil was all I replaced.
Someone else who has the pleasure of a coil leak out and the damage done will slide by eventually.
Old Aug 5, 2014 | 07:26 AM
twocross's Avatar
It is an 1985 XJ6 4.2, sorry for not being clear enough initially.
I'm especially curious if a fuel injection component could get damaged.
Old Aug 5, 2014 | 07:43 AM
Doug's Avatar
Hmmm. I've not ever seen or heard of any damage being done from the oil leaking out......except to the coil itself, that is. The oil is in the coil to keep it cool.
The only tie-in to the F. I. system I can think of is the white/black ECU trigger wire coming off the "-" coil post. I'm not sure how a overheated coil could damage anything via that wire.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
kelliott
May 31, 2022 05:26 PM
Scarecrow
Mar 28, 2016 03:17 AM
Dymaxxion
Sep 4, 2015 02:40 PM
