ignition switch 1972 xj6
The ignition switch won't turn the engine off? 305 chev conversion. Have to ground out the ignition switch.
"Ground out" I don't get it.
From way out there I suspect one or both of the following: 1. Errant back feed. diode needed, not in the circuit. 2. Internal switch issue. So, other than the white wire from the switch to the coil + poast, is there any other? Carl Carl |
Originally Posted by JagCad
(Post 2002537)
