Injector relay
Old Jun 15, 2016 | 10:23 AM
bendougy's Avatar
Default Injector relay
My 83 xj6 is intermittently stopping. My start relay has started chattering on start up. Sometimes it starts when I can hear the injectors working. It motors over well. Why are my injectors intermittant
Old Jun 15, 2016 | 10:38 AM
Doug's Avatar
Does this occur only when hot? Only when cold? Any particulars?
Possibilities: Low voltage, poor connections, dirty contacts inside the relay
Not quite sure what you mean here
If you sure that the injectors are intermittent check the connections at the 'main' relay and the injectors ballast---which is mounted on the RH inner fender, well forward and down low. Also check the bundle of ground wires at the rear of the water rail
Old Jun 15, 2016 | 02:46 PM
bendougy's Avatar
The symptom occurs hot or cold. The starter motor works well, it only starts when I can hear the injectors clicking. Problem still occurs when jump starting so not a voltage problem. Shall look in fender for main relay when back home.
DJS
May 23, 2017 04:37 PM
Gerard Radimaker
51
Jul 1, 2016 07:55 AM
philc850
62
Jun 28, 2016 10:37 AM
scardini1
May 17, 2016 04:21 PM
Nee_the_Bogeyman
Apr 3, 2016 10:41 PM
