The keys to Lucas Wiring
Been doing some computer cleanup and came across this I had stashed away. May be of some help to somebody..
Where does this color wire go? While looking at pages of Lucas humor I stumbled upon this list of color coding for wires and thought it might be useful to some. From: ( http://www.peterrenn.clara.net/archive4.html ) So there you are, grubby Haynes Manual in one hand, circuit tester in the other trying to work out why the lights/horn/wipers/cigarette lighter/clock etc. won't work, (apart from the fact that it has 'Lucas' stamped on it that is.) Tracing the circuit usually works eventually but often you find yourself with several loose wires and no clues as to where they go, in which case you need a clue or two. There is a British Standard for vehicle wiring (who said "abysmally low"?) number BS-AU7a which defines the colours and allows you to trace where the wires should go from first principles rather than a diagram. It also allows accessories such as electric fans to be added with the correct coloured wires which assists later diagnosis enormously. None of this helps the fact that the things on the ends of the wires are usually made by Lucas too and are therefore of er.. variable quality! I'm particularly fond of a description of an E-type Jaguar's headlamp switch as having" three positions: DIM, FLICKER and OFF. Anyway, that's enough potentially libellous comments (I'm sure all Lucas products are simply fab nowadays and the repro stuff is only crap because it is so authentic This info should not only allow you to trace original wires but also to use the correct colours when adding additional equipment like spotlights, ejector seats or whatever. Firstly the basics- What The Colours Mean: BROWN is for direct, unswitched, unfused supply from the battery. Seen on wires to alternators, dynamos, control boxes and ignition switches etc. Always live and often carrying heavy current. YELLOW sometimes used as an alternative to brown on older cars. Also used on solenoids and overdrive switches. PURPLE Direct, unswitched but fused supply from the battery. On older cars with no purple wires, brown wires with a secondary tracer colour are used. WHITE Unfused supply from the ignition switch. GREEN Fused supply switched via the ignition switch. Used for things like the wiper motor, indicators and brake lights which only work when the ignition is on. BLUE The main colour for front lights- headlamps and spotlamps. RED The main colour for rear and side lights. BLACK Usual colour for wires from components to earth points on the body. These refer to the main colour of the wire. The second tracer colour which is on many wires is the thinner line and is used to identify the wire. There is a certain amount of logic to them too as you will see. Below is the colour code table for BS-AU7a which was amended in the 'eighties so there will be a few variations on our '50s to '70s cars.. Main colour is given first , tracer second MAINLY BLACK WIRES Black All earth connections Black/ Brown Tachometer generator to tachometer Black/ Blue Tachometer generator to tachometer Black/ Red Electric or electronic speedometer to sensor Black/ Purple Temperature switch to warning light Black/ Green Relay to radiator fan motor Black/ Light Green Vacuum brake switch or brake differential pressure valve to warning light and/or buzzer Black/ White Brake fluid level warning light to switch and handbrake switch, or radio to speakers Black/ Yellow Electric speedometer Black/ Orange Radiator fan motor to thermal switch MAINLY BLUE WIRES Blue Lighting switch (head) to dip switch Blue/ Brown Headlamp relay to headlamp fuse Blue/ Red Dip switch to headlamp dip beam fuse. Fuse to right-hand dip headlamp Blue/ Light green Headlamp wiper motor to headlamp wash pump motor Blue/ White a) Dip switch to headlamp main beam fuse b) Headlamp flasher to main beam fuse c) Dip switch main beam warning light d) Dip switch to long-range driving light switch Blue/ Yellow Long-range driving light switch to lamp Blue/ Black Fuse to right-hand main headlamp Blue/ Pink Fuse to left-hand dip headlamp Blue/ Slate Headlamp main beam fuse to left-hand headlamp or inboard headlamps when independently fused Blue/ Orange Fuse to right-hand dip headlamp MAINLY BROWN WIRES Brown Main battery lead Brown/ Blue Control box (compensated voltage control only) to ignition switch and lighting switch (feed) Brown/ Red Compression ignition starting aid to switch. Main battery feed to double pole ignition switch Brown/ Purple Alternator regulator feed Brown/ Green Dynamo 'F' to control box 'F' Alternator field 'F' to control box 'F' Brown/ White Ammeter to control box. Ammeter to main alternator terminal Brown/ Yellow Alternator to 'no charge' warning light Brown/ Black Alternator battery sensing lead Brown/ Slate Starter relay contact to starter solenoid Brown/ Orange Fuel shut-off (diesel stop) MAINLY GREEN WIRES Green Accessories fused via ignition switch Green/Brown Switch to reverse lamp Green/ Blue Water temperature gauge to temperature unit Green/ Red Direction indicator switch to left-hand flasher lamps Green/ Purple Stop lamp switch to stop lamps, or stop lamp switch to lamp failure unit Green/ Light green Hazard flasher unit to hazard pilot lamp or lamp failure unit to stop lamp bulbs Green/ White Direction indicator switch to right hand flasher lamps Green/ Yellow Heater motor to switch single speed (or to 'slow' on two- or three-speed motor) Green/ Black Fuel gauge to fuel tank unit or changeover switch or voltage stabilizer to tank units Green/ Pink Fuse to flasher unit Green/ Slate a) Heater motor to switch ('fast' on two- or three-speed motor) b) Coolant level unit to warning light Green/ Orange Low fuel level switch to warning light Light green Instrument voltage stabilizer to instruments Light green/ Brown Flasher switch to flasher unit Light green/ Blue a) Flasher switch to left-hand flasher warning light b) Coolant level sensor to control unit c) Test switch to coolant level control unit Light green/ Red Fuel tank changeover switch to right-hand tank unit or entry and exit door closed switch to door actuator Light green/ Purple Flasher unit to flasher warning light Light green/ Green Start inhibitor relay to change speed switch; or switch to heater blower motor second speed on three-speed unit Light green/ White Low air pressure switch to buzzer and warning light Flasher switch to right-hand warning light; or Light green/ Yellow differential lock switch to differential lock warning light Light green /Black Front screen jet switch to screen jet motor Light green /Slate Fuel tank changeover switch to left-hand tank unit; or entry and exit door open switch to door actuator Light green/ Orange Rear window wash switch to wash pump; or cab lock-down switch to warning light MAINLY ORANGE WIRES Orange Wiper circuits fused via ignition switch Orange/ Blue Switch to front screen wiper motor first speed timer or intermittent unit Orange/ Green Switch to front screen wiper motor second speed Orange/ Black Switch to front screen wiper motor parking circuit, timer or intermittent unit Orange/ Purple Timer or intermittent unit to motor parking circuit Orange/ White Timer or intermittent unit to motor parking circuit Orange/ Yellow Switch to headlamp or rear window wiper motor feed, timer or relay coil Orange/Light green Switch to headlamp or rear window wiper motor parking circuit timer or relay coil Orange/ Pink Timer or relay to headlamp or rear window wiper motor feed Orange/ Slate Timer or relay to headlamp or rear window wiper motor parking circuit MAINLY PURPLE WIRES Purple Accessories fed direct from battery via fuse Purple/ Brown Horn fuse to horn relay when horn is fused separately Purple/ Blue Fuse to heated rear window relay or switch and warning light Purple/ Red Switches to map light, under bonnet light, glove box light and boot lamp when fed direct from battery fuse Purple/ Green Fuse to hazard flasher Purple/ Light green Fuse to relay for screen demist Purple/ White Interior lights to switch (subsidiary circuit door safety lights to switch) Purple/ Yellow Horn to horn relay Purple/ Black Horn to horn relay to horn push Purple/ Pink Rear heated window to switch or relay Purple/ Slate Aerial lift motor to switch up Purple/ Orange Aerial lift motor to switch down MAINLY RED WIRES Red Main feed to all circuits mastered by sidelamp switch Red/ Brown Rear fog guard switch to lamps Red/ Blue Front fog lamp fuse to fog lamp switch Red/ Purple Switches to map light, under bonnet light, glove box light and boot lamp when sidelamp circuit fed Red/ Green Bulb failure unit to right-hand-side and rear lamps Red/ White a) Sidelamp fuse to right-hand side and rear lamps b) Sidelamp fuse to panel light rheostat c) Fuse to panel light switch or rheostat d) Fuse to fibre optic source Red / Yellow Fog lamp switch to fog lamp or front fog fuse to fog lamps Red/ Black Left-hand, sidelamp fuse to side and tail lamps and number plate illumination Red/ Pink Sidelamp fuse to lighting relay Red/ Slate Lamp failure unit to left-hand side and tail lamps Red/ Orange Fusebox to rear fog guard switch Red/ Slate Window lift main lead MAINLY WHITE WIRES White Ignition switch or starter solenoid to ballast resistor White/ Brown Oil pressure switch to warning light or gauge, or starter relay to oil pressure switch. Choke switch to choke solenoid (unfused) and/or choke to White/ Blue switch to warning light, or electronic ignition distributor to drive resistor. Starter switch to starter solenoid or inhibitor switch White/ Red or starter relay or ignition (start position) to bulb failure unit White/ Purple Fuel pump no 1 or right-hand to changeover switch White/ Green Fuel pump no 2 or left-hand to changeover switch. Start switch to starter interlock or oil pressure switch White/ Light green to fuel pump or start inhibitor switch to starter relay or solenoid White/ Yellow Ballast resistor to coil or starter solenoid to coil. Ignition coil contact breaker to distributor contact White/ Black breaker, or distributor side of coil to voltage impulse tachometer White/ Pink Ignition switch to radio fuse White/ Slate Current tachometer to ignition coil White/ Orange Hazard warning lead to switch White/Yellow a) Overdrive b) Petrol injection c) Door locks d) Gear selector switch to start PINK WIRE(!) Pink/ white Ballast terminal to ignition distributor That's all folks! The usual disclaimer applies., ie that This is correct to the best of my knowledge but you use this information at your own risk. So don't sue me if you blow your alternator or fry all your relays... - See more at: Where does this color wire go? - See more at: Where does this color wire go? |
Thanks for that, a lot of people don't know that there was a UK standard for wiring colours. Of course as time went by and more and more electrical stuff was added to cars, the standard had to supply more and more tracer colours. I think "Slate" came in when I was in my 20s.
And there was me thinking the key to Lucas wiring was not letting the smoke out!
I looked at the title and expected a picture of a couple of keys with the gates of hell in the background. Thanks for the info, it all helps.
Joseph Lucus Electrical Theory
1 Attachment(s)
I've always found this helpful when confronted with an English motoring electrical conundrum :)
Pretty funny...
Love it! Thanks for sharing Nigel
1 Attachment(s)
Originally Posted by andrew lowe
(Post 1392987)
Attachment 125040 |
Agree, very nice. the link would not open here. So, I saved the entire thread!!!
Some years ago, a lot of them, I was driving home through a part of Hollywood. An older car was off to the side with smoke from the hood. American car, no Lucas stuff??? I opened the hood and saw smoking wires. I grabbed a too from my tool box and snatched off the battery ground cable. smoking stopped. the "mature" lady was eloquent in her praise. I saved her car. I just did not have the heart to tell her that fixing it would cost more than the car was worth. The fire guys arrived. I was complimented. They told me they used bolt cutters in similar circumstance. Many a car has perished along the roadway for lack of urgent attention with a tool to stop the smoke.... Carl |
Yes. 2 things I always keep in the car - fire extinguisher and stout cable snippers (capable of cutting through a positive battery able in one quick snip).
No sense on freaking out about smoking wires if you are prepared, and have given some thought about what to do in that eventuality. However I am wondering about what those folks with their electric cars do if they are involved in an a car accident and an electrical fire ensues...I might be a bit hesitant about getting too close to it with my trusty snippers..... |
having fun behind the dash. i have the same general info on my wire colour chart yet i cant figure the placement or purpose of some wires, i mean the light green/black one seems to have no impact on the wipers, and there are a couple of short trimmed wires (purple/black and lightgreen/brown) which seem to do zero but also seem to be in critical spots. i think they put too many wires in these things :)
https://cimg1.ibsrv.net/gimg/www.jag...a19e266b3f.jpg general mess https://cimg2.ibsrv.net/gimg/www.jag...4f0dd216e2.jpg general mess 2 https://cimg3.ibsrv.net/gimg/www.jag...3c74625e82.jpg a rogue purple/black wire with voltage on it https://cimg5.ibsrv.net/gimg/www.jag...43d47ae209.jpg a light green with black stripe, should be wipers but wipers work without it plugged in .. so |
Boy Howdy does that look familiar!!
Windscreen washers, I think.
I have two Jags and electronically they are and have been congruent and stable. I don't subscribe to all the jokes and cursing about Lucas wiring. Without a doubt, whenever there is an issue with wiring, it was CAUSED by an owner.
I agree Jose,
Although wiring in Nix was definitely Not unmolested, everything has worked as intended from day one of my ownership. Problems with components have mostly been lack of maintenance and lubrication. I've had far more Deferred Maintenance and Lazy PO issues than electrical problems. (';') |
Poor Joe Lucas, the automotive world's favorite whipping post, has been excessively maligned.
I work on a large variety of oldie cars. I've never come across a Lucas problem that I haven't seen the same or similar on any other oldie car. The problem with Lucas and Jaguar is that Jaguar held onto some of the older technology too long. Most notably, Jaguar was using unsealed connections well into the 80s while others, even 'ordinary' makes, had moved on to more modern methods. This was Jaguar penny-pinching. I'm quite sure that Lucas would've gladly provided more modern electrics to Jaguar....for a price. Cheers DD |
