Leaking exhaust manifold xj6 s3 1985
Received 2,399 Likes
You have an excellent chance of making that work. The risk is busting a stud or another ear. Care, corrosion blaster and perhaps heat.
If you are extremely lucky a PO used brass nuts and a lot of antiseize.
Do that on the "fix".
When I removed the DOHC from my car, those nuts came free sans angst.
Carl
Carl
If ypu look at the manifold you will see it has the 4 spots for studs however, the plate that holds downpipe up to manifold only has.two holes, one of my.studs got snapped off when.i redid.head, i simply bought new studs, and put them.in the other two spots, made it.a bit more difficult to get onto one of the nuts, but i managed... good luck!
Received 8,934 Likes
