Low speed blower and wipers
My wipers stopped working and I swore I read somewhere that #6 driver side USA 35A fuse controlled both wipers and some blower function...even though door card says 35A #6 "Wipers"
But now when I turn on Low blower speed nothing happens when I swear it used to run at low speed compared to high
Replaced fuse but no joy...found a good debug post about wipers dying but curious about the wiper/blower fuse statement. Di I imagine I read that??
Randy
Randy
Fuse 6 does relate to [at least some portion of] climate control function. But if any of the blower speeds are working I'm pretty sure #6 wouldn't be the culprit.
An easy place to start for blower speed problems in the blower relay pack behind the LH cheek panel of the console. Look for scorched and/or loose connections. The relay pack in four relays in a single black box. You'll recognize it easily when you pull the cheek panel
manycars
Nov 21, 2015 08:46 AM
mhamilton
Jan 13, 2014 07:18 AM
