Lowering springs for early 80s xj 6, PDX, OR
Old Jul 9, 2025 | 08:50 PM
OregonTarheel's Avatar
Default Lowering springs for early 80s xj 6, PDX, OR
I have a jag front suspension on my 1946 Chevy pickup. It fits great and works well. I am trying to lower it a bit from stock/factory height. I don’t want to cut or heat the factory springs. Are there any after market options? I found King Springs, but they don’t lower it enough. Only 2 inches or so.
Many thanks!!
Old Jul 10, 2025 | 04:03 PM
slofut's Avatar
The springs are gonna get awfully short past the drop of King springs. Even just removing all the spring pads from the stock springs (wait, have you tried that first?) leaves them pretty short. You may be looking at some skeletal surgery.
Old Jul 10, 2025 | 06:39 PM
Wooford XJR's Avatar
On Series III XJ6, you dont need to cut the spring to lower the suspension. The spring bucket on the lower control arm unbolts from the A-arm. You get longer bolts and make spacers or use washers to create a gap between the spring bucket and lower arm. I not certain that series I & II are the same but I would bet they are. Someone else on the forum can possibly verify.
Wooford XJR
Old Jul 11, 2025 | 04:35 PM
slofut's Avatar
Wooford XJR
They are and I've used that method on my ser 2 also, but I wouldn't recommend a deep drop this way unless some method of strengthening that connection is made.
Old Jul 11, 2025 | 04:36 PM
slofut's Avatar
Wooford XJR
They are and I've used that method on my ser 2 also, but I wouldn't recommend a deep drop this way unless some method of strengthening that connection is made. Jmho
Old Jul 12, 2025 | 05:17 AM
Jose's Avatar
worn out springs coupled with 60 series tires will let you scrape the asphalt to your satisfaction.
Old Jul 12, 2025 | 12:44 PM
slofut's Avatar
Old Jul 13, 2025 | 09:29 AM
icsamerica's Avatar
30 minute Job if you have the spacers and longer bolts on hand. The bolts need to be 3/8-24 grade 8. The 2 longer bolts that hold the lower stock mounting bracket are a bit of a pain.
eurolat
Mar 22, 2018 07:11 AM
Daim
Mar 4, 2018 07:39 AM
dr.fixit
Sep 30, 2017 01:43 AM
ultrablu
May 8, 2015 11:15 PM
