moving the crankshaft
Old 09-26-2014, 03:29 PM
Series1fan's Avatar
Default moving the crankshaft
Hi all, busy working on the distributor contacts and the static timing. Think I know what I'm doing but...
first I have to turn the crankshaft. I know this is pretty basic but what size/kind spanner? (Car didn't come with original tool kit).
Further, to get leverage, is it necessary to unbolt the fan and shift it out of the way? I have an automatic (I understand that in a manual you can shift the crankshaft by working the gears and moving the car some).
As I work on this this weekend more complicated questions might follow but, for now, I just got to get started.
Thanks,
Old 09-27-2014, 05:16 AM
Received 5,838 Likes on 4,183 Posts
Memory, HAHA.
That big nut head is 1", I think??
Should be able to reach it from underneath.
On the S2 there is a hex cast into the pulley of the water pump for just that purpose, and that one is 32mm.
ONLY wind that engine "clockwise" as looking at the front, so if you go past the timing mark, go around again, and be more careful. An assistant here is really a must.
Series1fan (09-27-2014)
Old 09-27-2014, 01:58 PM
Series1fan's Avatar
Thank you, Grant!
Good to know about the "clockwise only" part, too.
Off to get that spanner then...
Old 09-27-2014, 09:33 PM
Series1fan's Avatar
Actually, once under car, discovered the crankshaft nut is significantly bigger than 1 inch. Finally found 2 internet sources saying same : 1 5/16" Got that spanner on order and will post back here. One source from Jag-lovers says best to move the fan, too. Hoping that isn't necessary as setting the timing is not an uncommon thing t have to do.
jimforrest (uk)
02-28-2019 06:42 PM
adam699
10-13-2015 05:53 PM
Johnken
10-02-2015 10:12 AM
Glenn Barickman
10-01-2015 04:09 PM
Quick Reply: moving the crankshaft
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
