Mystery bulb?
Old Jun 14, 2020 | 08:08 PM
Series1fan's Avatar
Default Mystery bulb?
Hi all, today when replacing the old cigar lighter, I found a bulb by the gear selector, but just laying there: it is connected to a pretty long wire but nothing else. It's not the bulb on the gear selector itself (it's still in situ). Any ideas where it goes or what it illumines?
Mine is a 1971 Series 1. I have done a fair bit of work on the car but this is the first time opening up the area around the gear lever.
I switched on the interior lights but the bulb did not light up. As you see from the photo, it is in a cradle that looks old but I don't know if it is stock.
Thanks for any help,
File Type: mov
Old Jun 14, 2020 | 08:34 PM
Larry Louton's Avatar
Could it be a bulb that illuminates the cigar lighter? Window on side of lighter assy?
Larry Louton
Old Jun 15, 2020 | 09:27 AM
Looks like the lighter bulb as Larry says.
But maybe the mounting bracket has broken off the lighter socket, where it gets its ground/earth.
Old Jun 15, 2020 | 08:07 PM
Series1fan's Avatar
Larry, you are quite right! Odd thing is the replacement I got from SNG doesn't have that cut out in the sleeve but when I looked back at the old one (the sleeve was corroded and locked firm to the inner casing so I've had to use a grinder to get it out) there's a space and the little mounting housing (LnrB: yep, still attached) clips right in. How cool is that? Thanks!
I might try to cut a similar hole in the SNG sleeve so I can mount in the original bulb. If I am successful I'll post a picture (more likely I'll damage the sleeve). I might call Moss and see if their replacement part has the aperture for bulb mounting.
Anyway, thanks for solving the mystery! I had no idea Jaguar had such a cool detail on the car.
Old Jun 15, 2020 | 08:35 PM
I suspect that the idea was so you would not miss the hole while reinstalling the lighter!!!
Your welcome
Larry Louton
Leet8845
Nov 21, 2017 04:20 PM
YycXJS
Feb 18, 2014 10:24 AM
Guyver68
Jan 19, 2014 01:34 PM
Paul A
Sep 24, 2010 05:15 AM
magmedia
Apr 7, 2010 05:18 PM
