No high beam when activating inner steering column switch
Old Feb 20, 2018 | 02:56 PM
new mexico's Avatar
Question No high beam when activating inner steering column switch
I get no high beams when I lift the column switch, could it be a bad
relay by the radiator??????
1978 XJ6 ser.2
Thanks ,
Walter
Old Feb 20, 2018 | 04:34 PM
Jose's Avatar
lift or pull ?
to get the FLASH-TO-PASS function, you pull the stalk switch towards you.
to get the HIGH BEAMS you push it forward.
Unless it is different in your Series 2, which I doubt since I have two or three Series 2 stalk switches and they are the same as my Series 3.
The second step is to check the headlight fuses by rolling them in their contacts, or replacing them if bad.
09XFwhippin
Nov 28, 2016 11:22 PM
Anthony8858
Sep 5, 2016 10:48 AM
cybercg
Sep 30, 2013 03:43 PM
daboss085
Nov 1, 2012 05:13 PM
Jan 2, 2007 04:37 PM
