Odd windscreen trim on Series 2.
Bought a Series 2 and it came with this windscreen trim. Is this OEM and can it be swapped out with OEM 2 piece style? Any help would be appreciated. Thanks.
https://cimg2.ibsrv.net/gimg/www.jag...8a3c157a64.jpg https://cimg7.ibsrv.net/gimg/www.jag...a5fe340a3d.jpg |
looks like brackets for a Visor
They're a seam finisher for lack of a better word. I've seen another car on C/L with the same and the pieces on Ebay for sale. They have a bracket behind the rubber / chrome piece.
Mine has a small one top centre only like your bottom one.....my guess would agree with Jose. |
I'm told by someone who claims to know, that the "clips" on Series 2 windshield trim were mandated by the US Department of Transportation to keep the chrome edging from flying off in the wind, startling drivers behind and generally causing havoc.
Considering how difficult it is to reinstall said trim properly and securely, this just might be true. (';') |
LnrB, I think your right and here's a pic of the $100k XJC with them also. Here's a pic of them on there own from Ebay. I'm hoping someone here knows if I can swap it with the 2 piece style. It's not bad from 20ft but up close it looks a bit hideous.
https://cimg3.ibsrv.net/gimg/www.jag...cd71f04ba9.jpg https://cimg6.ibsrv.net/gimg/www.jag...754cd92321.jpg |
I think it's only 2 pieces anyway. At least the one we recently got from the wrecking yard was only 2 pieces.
They bolt together in the center of top. I don't remember what holds the bottom center together besides a lot of hope. The side clips bolt through holes in the finisher and roof. There is no seam under them. (';') |
II asked Paul in Ft Lauderdale the same question years ago and got the answer that the two piece will not fit and we are stuck with the trim pieces.
Bill |
Later on today I'll check the salvage trim I have out in the shed and post a picture.
As Promised...
https://cimg2.ibsrv.net/gimg/www.jag...74bf72786b.jpg
This is the top right side of the windshield finisher for Series 2; Notice holes for the three hold-downs as mandated by the US-DOT. https://cimg2.ibsrv.net/gimg/www.jag...84d5885ea2.jpg This is the top left of the windshield finisher for Series 2. https://cimg2.ibsrv.net/gimg/www.jag...1627b7eaa3.jpg This is the bottom center of the windshield finisher for Series 2. There is also a mounting hole under the decorative cover. https://cimg4.ibsrv.net/gimg/www.jag...555962fe2d.jpg Both halves of the complete finisher. These parts along with the windshield were taken from a complete Series 2, (';') |
Originally Posted by LnrB
(Post 2029866)
Thanks LnrB for taking the time to snap those pics. I was assuming the clips were for windscreen containment and Icsamerica's post confirms it for me.
A couple of questions - 1. Aren't series 1 windshields held in by the same seal / gasket set up as this w/o clips/retainers? Are they that easy to pop out? 2. All the pics of cars and part numbers I've found on the net are absent the retainers. Are these all euro cars/part #'s? 3. How are later model series 2 windscreen trim/seals held in? Thanks again for everyone's help. |
Yup. Ditto. At about that time, cabon security for passengers was hetting a lot of needed attention. Much safer to stay in and remain secure fdrom incoming whatewvers…
Carl |
Originally Posted by gboy
(Post 2030522)
A couple of questions - 1. Aren't series 1 windshields held in by the same seal / gasket set up as this w/o clips/retainers? Are they that easy to pop out? 2. All the pics of cars and part numbers I've found on the net are absent the retainers. Are these all euro cars/part #'s? 3. How are later model series 2 windscreen trim/seals held in? Thanks again for everyone's help. 2. The reason they aren't in the Series 1 parts manual is because they started being added in 1973, so you'd have to get a very late parts manual for them to be in it. I have a Series 1 manual printed in July 1974 that has those clips in it. 3. As far as I can recall, the Series 2 kept those clips to the end of the run. The Series 3 was able to drop them because of the way the windscreen was sealed in place. It's much tougher to get out. As far as I know, The early Series 1 trim without the brackets will fit on the 73 and later cars to 78. Whether it's the most sound choice is debatable... Cheers David shop.EverydayXJ.com |
