Part ID
Okay, south of heading to my local Jag dealer: Does anyone know where I can acquire a new condensation drain hose? This is one of the shaped rubber tubes with the cats-eye bulb on the end that sits behind the engine on the firewall (and gets destroyed by the heat). I've hit Jabits and Welsh with no luck so far (I suspect I'm failing to describe it properly), and am about ready to re-purpose one from my MG...
The elbow is part number BD46543 and the 'duckbill' piece at the end is BD34737. Google those numbers with the word 'Jaguar' and you should get some hits.
However, those are not condensation drains. Those are the drain for the air intake plenum below the windshield wiper arms. The condensation drains are attched to the bottom the the climate control evaporator case and actually poke thru the floor boards. CAC2299 is the part number Cheers DD |
Well, that explains why my searches weren't working. 'Preciate it!
