power antenna failure
pretty sure the motor in the boot to the antenna is dead..anyone know if this can be fitted to a manual one?
Are you asking if a manual antenna can be installed...or what?
Cheers DD |
yes, can i replace it with a manual antenna as long as the clearance is there inside the qtr panel behind the tail lamp assembly? i'd imagine so
I don't see any reason why not. Neither the car nor the radio knows if the antena is power operated or not.
Cheers DD |
i thought mine was dead..so did my expert mechanic
i swapped out the relay...works as good as ever. WINNING!!! |
unless i'm looking at the wrong relay..its seems that my antenna runs to the same relay as the fuel pump...i think the relay is fine...gona trying hammering it tomorrow.
Doghead,
My antenna just went out today (must be something in the air)... can you post a pic of that relay? Mine is stuck in the up position and car cover will not go on now. Thanks.....Scott |
BTW... in addition the fuse keeps blowing on the antenna/interior light circuit. Did anyone else have this issue?
Assuming original parts and not aftermarket replacements, the antenna relay is usually lite green and mounted on or near the antenna motor....which is a couple feet away from the antenna itself, the two being connected by conduit with a cable inside. It's on the same fuse as (some of) the interior lights. When the fuse blows it can, on some models, cause the door lights to stay dimly lit at all times.
The relay incorporates a timer to delay retraction of the antenna The fuel pump relay is on the firewall Cheers DD |
Originally Posted by sneal46
(Post 391646)
Cheers DD |
blown fuses
i blew 3 or 4 fuses trying to get the relay wired correctly. since then the aerial has been working like a champ.
if you still need, ill send you the pick tomorrow you can go run a search and see what it looks like |
great, i'd appreciate it.
A pic would be helpful. Also... where did you find a new relay for the antenna? It has 5-6 wires on it, not like the fuel relay which is more generic.
just bought a used one on ebay, should be here any day now. Its green and in the spare tire compartment...didnt know where to look for a new one.
The power antenna on my 76 XJ6 has been running great. But when I arrived home tonight and turned the car off the antenna did not retract. I checked the fuse in the truck near the spare and it had blown, I put in another and it blew. What could the issue be, could the relay be shot?
Power antenna failure
My antenna failed on my 77 XJ6 motor kept running it was a broken cable from the motor to the antenna itself. After a fruitless search for repair parts I decided to replace it with a manual. Found one on ebay for 20 bucks I believe it was for a toyota truck the angle for the chrome bezel is very steep so you have to be careful it fit perfectly with minor mods
My "new" 2007 Jag XK Antena doesn't retract all the way, leaves the last section up. Any ideas on why?
Thanks |
Repair it
If you remove the entire apparatus from the car and clean it (especially the telescoping sections of the mast) There is a drain hole in the bottom of the motor casing to let water out. Water that has seeped in by coming down the mast settles in the bottom of the casing. These are easy to disassemble and clean, with the mast fully extended , wipe it with some light oil on a rag. If it has never been lubed dirt gets collected in the mast section and eventually the resistance to operate over comes the fuse rating and the fuse blows.
They are not that difficult to disassemble ,clean, reassemble. Mine on my 86 works just fine, but I make sure the telescoping action is clean, has been wiped with an oily rag recently and runs smoothly. Don't give up on it rather learn how it works - that's the beauty of these cars when every thing works they are quite a joy. |
