rear defroster/winshield washer fluid
when i had my windows tinted, the wires that attach to each side of the rear window came un done. what is the best way to reattach and make operable again?
also my washer fluid doesntshoot out? im not even hearing any noise when i press the device to shoot the fluid. where should i begin |
Originally Posted by doghead08
(Post 403148)
also my washer fluid doesntshoot out? im not even hearing any noise when i press the device to shoot the fluid. where should i begin Wires: Never had to fix one before, nor even taken close notice, but I think they're just soldered on. Others will chime in Washers: Is the pump plugged in? It's at the bottom of the reservoir Cheers DD |
windshield washer pump
i went ahead and checked the wiring. it is definately plugged in and tracked the wires. they head right underneath the fuse box under the hood.
maybe a bad relay? do you know where thats located theres a pretty good chance itsprob a bad pump |
(Post 403255)
(Post 403255)
maybe a bad relay? do you know where thats located theres a pretty good chance itsprob a bad pump No relay. The light green wire to the pump should have 12v from fuse #11 with the key "on". The light green/black wire should show "ground" when the washer button is pushed. If that checks out OK then, yes, you have a dead pump Cheers DD |
