???? relay location ????
Old May 27, 2022 | 10:25 AM
retroren's Avatar
Default ???? relay location ????
hi: where are the relays shown in the upper left corner of this schematic located in the car? behind the glove box?
Old May 27, 2022 | 12:01 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
I believe they are in the black box seen in this picture.
Dave
Old May 27, 2022 | 12:05 PM
Greg in France's Avatar
Correct. You will find them by undoing the vent and removing the LHS tunnel vent cheek, fixed to the side of the HVAC unit.
Old May 28, 2022 | 12:27 PM
kudzu's Avatar
Hi, here's a picture of the relay unit shown above as seen after removing the left cheek panel / vent. It's the black box in the middle that the maze of wiring plugs into. The round connector to the amplifier is to the right with the "L" shaped amp itself hidden behind everything.
Cheers,
Brian
Old May 28, 2022 | 07:50 PM
retroren's Avatar
I Salvaged these two from a junk car so I know how to get at them The amplifier is on the left. Is the box on the right what contains the four colored relays referenced in the schematic? I was looking for the usual cube shaped relays
Old May 28, 2022 | 09:03 PM
Doug's Avatar
Yes, it's 4 relays in one box.
rayclark1
Nov 11, 2018 11:26 PM
Terrific
Jul 21, 2018 01:56 PM
JensenHealey
Feb 25, 2017 07:20 PM
user 2029223
Nov 5, 2015 03:46 PM
XJ6Aficionado
Sep 19, 2012 08:47 PM
